MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,321
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Some are on display at various museums, others are at Davis-Monthan AFB.
What you really want is a suit of beryllium armor with kevlar undersuit.
I welded a lot of Titanium piping and it was a strict no-no to expose Titanium welds to atmospheric oxygen when above 500F IIRC. We had to have argon gas coverage on the weld when TIG welding it. We did this either in a argon purged Plexiglas container or by fabricating a trailer that was attached to the TIG torch and kept inert gas on the hot weld. Weld length was a little less than the length of the trailer and we had to stop and let it cool. If we removed it too quickly, the titanium weld would change from a bright silver to gold then blue. Light Gold was sometime OK but dark gold indicated a titanium oxide had formed which was extremely hard and the weld would have to be ground out and replaced. We could quickly check it with a very sharp pointed tungsten welding electrode. If we could scratch it with the tungsten, it was ok. If it got too much O2 before cooling, it was so hard that no amount of pressure on the tungsten would leave a mark.Does anyone know how hot?
When the SR-71 Blackbirds were built back in the late 50's that is when titanium was developed as a material. A lot of trial and error heat treatment gage size etc. There are lots of good articles on the planes development. They initially had trouble drilling the titanium and that is when cobalt (M42) drills were developed. Penn State developed the engine fuel/ hydraulic fluid. The hydraulic fluid needed to withstand 800 degree F and then was burnt as fuel.Now again as I generally do, this from memory, so if I made an error or two here, it's on me. It is well worth the time to read the history of the SR-71A. I think i still have a couple of VHS tapes on the planes developement. Later
I'd rather have the titanium, much lighter weight and comes in sheet form. It is hard to drill through and form, DC10's used it as a thin skin doubler around door frames, making it hard to do doubler repairs in the cracked Aluminum cutouts. Never seen Beryllium in sheet, usually as a rod for making bushing/bearings. Very hard wear surface but it is nasty/toxic material to work with. They made tools out of it for working in highly explosive areas like mines and missile silos so if you drop a tool it won't spark. The Beryl co. was one maker of sockets I've seen. I have a claw hammer that was my wife's grandfathers who used to work as a carpenter in mines back in the 30's-40's. Looks like a brass hammer but a little more coppery looking.
