how do you change the time on a Kubota stereo?
   / how do you change the time on a Kubota stereo?
right, in every car i've ever owned, that works. with this stereo, problem is that as soon as i start to try to change time, stereo turns back on.
dealer is stumped too - i'll try removing power to the stereo to reset it as suggested earlier - that often works wonders for all sorts of electronic devices....
Figured it out: problem with the display button on my radio.
If I press the middle of the display button, it will change the display mode, but no matter how long I hold it down, the radio won't enter time set mode.
Pressing on the right edge of the button does trigger time set mode. I suspect the key cap (the part you actually press) isn't quite aligned with the mechanical button underneath it.
2012 FREIGHTLINER CORONADO 122 (A55745)
2012 FREIGHTLINER...
2016 Freightliner Cascadia Tandem Axle Road Tractor (A47477)
2016 Freightliner...
2017 TRAVIS BODY & TRAILER END DUMP (A55745)
2017 TRAVIS BODY &...
20' 18" Corrugated Pipe (A53316)
20' 18" Corrugated...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
23'x22' Double Garage Metal Shed (A53316)
23'x22' Double...
