How do you light your bonfires?
   / How do you light your bonfires? #52
Question --- how many actually skipped the ad before watching the video?
MoKelly
There was no ad to skip when I watched it just now.
   / How do you light your bonfires? #53
That video is priceless and HIGHLY educational. I have seen it numerous times before. But it begs the question. Why does my gasoline never have enough octane or omff, left to run my 2 cycle garbage, but will blow me to Mars if it gets the chance?
   / How do you light your bonfires? #54
I'm sure this will spark some discussion; flare gun...
   / How do you light your bonfires? #55
I use cardboard and newspaper in a pile. Add the driest branches I've got over to a modest size pile. Pour old motor oil over that pile and light the paper. Feed the fire as I go. I used to light the entire pile I had, but I like controlling how hot and fast it burns.
I usually burn a full day, three of four times a year... although my need to has been going down the longer we've been on this property. I used to burn old brush, branches, dead trees on the property in the woods... but found even in a clearing, the trees around the edge would have their roots burned and fall over with time. Now I just make piles. I figure it's a house for critters, so it's a win/win.
   / How do you light your bonfires? #56
I use the fire starter bricks. Find an area with good starting material and then set a brick under it. Once it's going good then add some used oil or diesel fuel to make it spread. Then keep it pushed tight with the dozer. As it may take 3 or 4 days to burn a brush pile made with the dozer.
   / How do you light your bonfires? #57
I use diesel. The piles are dead trees and freshly pulled cedar trees. Doesn't take much to get it going! :thumbsup:
   / How do you light your bonfires? #58
I now just pile brush generally for wildlife. My Dad would build a huge pile in the middle of a field. He would take a huge old tarp and have us kids spread it over the center of the pile. Then he waited for a rain. Just after the rain he'd pull the tarp, get some hay bale sections soaked in kerosene and chuck them in, then light with a torch. Worked well. Never lost control and usually had nothing left but ash.
I am burning some old dead locust stumps this spring by covering them with tarps then, when I'm ready, filling them with some old scraps of lumber I have and pouring a bit of kero on them. I expect they'll take some time to burn. They are about 5 feet tall. Can't cut them further because they were used to hold a fence over a century and are full of nails.
   / How do you light your bonfires? #59
I use a propane weed burner.
E/S
   / How do you light your bonfires? #60
The forestry service here uses a mix of gas and diesel, don't know what the mix is. Then they put it in a heavy iron pot with a screw on lid. There is a piece of 1/4" pipe welded to the lid with a loop bent in the middle. In the end is a piece of rag twisted into it. You pour some mix out so the rag is soaked and light the rag on fire. Then you just pour out burning mix and it drips out fire. Works well, just walk along and leave a trail of fire behind you.
BTW the spring no burn season has started here.
When my brother worked for the Forestry Service here in Florida they used a mixture of 2 parts diesel to one part gas and a rig like the one mentioned here.
We do not have a rig like that but the mixture still works just fine for starting a brush pile.
We just burned two of them Saturday. Just poured some of the mixture on a spot that had a good amount of dry, fast-burning material and lit it with a BBQ lighter .... then walk away. It does not flash or "wooosh" but the dry stuff may burn rapidly.
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
