How do you steer these machines?
   / How do you steer these machines? #11
kneedeep said:
Tractor mechanic told me that the dual brakes on a Ag tractor are for keeping the tractor following the rows whether straight or curved. Tractors tend not to turn with heavy ground engaging equipment like planters and cultivators. Thus, 'guiding' the tractor using the brake pedal to follow the row. He also stated that locking the brake to twist the tractor around eventually will damage the brake, or worse yet, break a axle. Proper way is to stop, raise equipment and turn even if you have to backup.
I bought a JD 950 years ago that the left brake was completly worn out from the old farmer 'spinning' the tractor at the end of the garden row. Everything was worn or broken on the left side and the right side had minimum wear. The tractor was only 4 years old and he planted about a acre garden.
Just my :2cents: worth
There is a world of difference in a 950 and a Ag tractor.
I have a 950, and not to say that the previous owner of your tractor didn't cause premature wear to the left side of the machine, but those brake drums collect dust and dirt, and you can wear out the brakes just driving.
   / How do you steer these machines? #14
kneedeep said:
He was talking about AG tractors- would the principle apply for any dual brake tractor :confused:
I was saying the AG tractors are built to handle it. Show me a farmer that will stop and backup to turn instead of using the brakes.
   / How do you steer these machines? #15
If you need to use breaks in the row you need a bigger tractor . Turning on the end with a 2wd is fine if the implement is raised .
   / How do you steer these machines? #16
With modern fwa on narrow mounted machines nearly all will stop and back up if headland is small .
   / How do you steer these machines? #17
Maybe things have changed but when I was growing up, we used full turning brakes every time we turned in the field. My brother still has some of those tractors (about 60 years old) and we never broke an axle or had unusual brake wear. We would raise the equipment if it was convenient but we'd still pivot on the brake. Backup? That would be embarrassing.
   / How do you steer these machines? #18
Isn't that why they are called steering brakes???
2872 (A58376)
2872 (A58376)
1986 Valve Drop Deck Trailer (A57148)
1986 Valve Drop...
REYNOLDS 14C SCRAPER (A58216)
REYNOLDS 14C...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2354 (A58376)
2354 (A58376)
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
