How do you test Hydraulic pump???? Ford 1910
   / How do you test Hydraulic pump???? Ford 1910 #11
Pops,
I too have a 1910. When I bought it I was told the hydraulics didnt work...and they didnt. I learned how this tractor worked and then resolved it. All I needed was a new filter and fluid. I know you changed the fluid already. Have you checked the intake screen on the suction side at the transmisson. If you have no lift think like this.
1 No pressure out due to loss of pressure along the way by either open diverter, or leak etc.
2 If your output was plugged somewhere the plug would have to withstand 3200 psi. Not a likely cause. Plus you would hear the engine loading down at a low rpm while the full power of the pump bled off thru the overpressure relief valve.
3. Most likely cause is that the suction is blocked and your pump is starved.
Flowmeter will tell this if the flow is low. But you can just open the line and check the intake screen on the tube. Mine was missing unless it wasnt in the tube but instead the transmission and I didnt stick my finger into the transmission hole. This screen is your highest probability. Or you can be sucking air due to a leak in the suction side of the line. Same symptom....no pressure. Last you can have water in the system. When you changed your fluid did you open all 3 drain plugs? 1 on rear differential, 1 on transmission, 1 on front wheel drive take off where the shaft hooks to transmission. These are the lowest points and all 3 will hold water. I failed to do this the first go round then figured it out later when foaming continued. Is your oil getting white and foamy or just lightly white and not too bubbly foamy on the dipstick?
Now for the goodies. I have a complete service manual and operators manual. I can copy you the diagrams, trouble shooting tests and pressure test points and power steering pressure relief valve setting procedure. Also the info on the operation of the hydro valve for the lift.
Let me know and we can get in touch on the phone or something. If you need a cheap pressure guage that can go to 5000 psi I bought 2 at Harbor Freight for $12.00 each. They are even fluid filled for dampening. You could get one and use it to see the actual output and even leave it in at all times if you wanted.
Let me know.....
Vic S.
   / How do you test Hydraulic pump???? Ford 1910 #12
sounds like you have a pump problem. The 1910 i believe is made in Japan.i worked on a ford 1920 , it had the same problem and the pump was bad. dont buy from ford i know a guy who can do better on prices
Where can you buy ahydralic pump for 1910 ford? Someone said that if power steering works it is not the pump. Is that true? thanks Ron
   / How do you test Hydraulic pump???? Ford 1910 #13
Hydraulic Bucket problem, The bucket will only move in one direction , the arm lifts fine but the bucket does not operate back and forth. This all started when the oil tank ran dry and I refilled with new oil. I have tried to check the "O" rings on the spool valve with no success in removing it, am I on the right track?
   / How do you test Hydraulic pump???? Ford 1910 #14
My bucket and box blade will not work at the same time, Low pressure and I dont know how to test. Power steering still works. It there anyone near Sunnyvale Texas that is reasonable to work on these? And where is the best place to buy a new pump if needed ,Thanks,Ron
   / How do you test Hydraulic pump???? Ford 1910 #15
If you only use half lever on each valve, they both will work.
   / How do you test Hydraulic pump???? Ford 1910 #16
:welcome:to TractorByNet!
Did you cycle the bucket curl valve enough to get any air out of the cylinders?
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
