How does bx 2350 mow compared to jd 485x
   / How does bx 2350 mow compared to jd 485x #1
inseeme
Stoneville, NC
Kubota M7040
I currently have a John Deere x485 which i have throughly enjoyed other that it sucking the gasoline. Am seriously considering trading it in on bx 2350 with 60"mmm will it mow as good as my x?
   / How does bx 2350 mow compared to jd 485x #2
"....will it mow as good as my x?"
What are you trying to compare, exactly?
My neighbor has an X. I've had a BX2200, and now a BX23.
We talk about it all the time.
Both do a fine job mowing.
Depends on which seat you are sitting in.
Just trying to see if the bx will mow any faster and can your neigbor mow a lot more grass on a tank of fuel versus, the x 485? Also my x485 has a really nice cut can the bx make the grass look as good as my x?
   / How does bx 2350 mow compared to jd 485x #4
I can't compare the BX to the JD because I've never used that JD. I can tell you that my BX 2230 (last year's version of the 2350) cuts a lot faster than my JD L130, but that's because I have a 60" mower now, instead of a 48". Besides, the diesel engine and heavier transmission on the BX allow me to mow up my hills at a much more consistent speed. Finally, the suspended self-balancing mower deck on the BX makes a more even cut than the JD's rigid deck.
As far as gas use, I am AMAZED at the fuel economy of my BX. I can't actually tell you how many gallons its taken to put 50 hours on my BX, but I can tell you its less than half what my JD used (which was a much lighter tractor, with a 23 HP Gas engine).
   / How does bx 2350 mow compared to jd 485x #5
I just replaced my JD318 with a BX-1850. The 318 had the heavy floating 50" and the Kubota has a 54" floater.
Both are very tough machines. The Kubota diesel engine has more torque and, just runs like a very tough diesel.
I suspect I get two to three times the fuel efficiency and far less evaporation. Of course one is 20 years older then the other so there are some design advantages :)
I really want to get the bx 2350 here is my main dilemma $3,000, is the bx2350 worth 3,000$ more than my x485. A friend said he would give me 7,000$ for my x, which has the power flow bagger, as well and only 91 hours just can't decide if I should make a move now or wait a few years? John Deere x hasn't gave me a minutes trouble at all and mows 4 acres in under 2 hours just wonder if bx would be better, the main reason I want it is for the diesel engine and 60 inch deck.je
   / How does bx 2350 mow compared to jd 485x #7
If you can get $7,000 out of a garden tractor I would not even hesitate. If you took that to a dealer to trade you would not nearly that much. The market for used garden tractors is horrible.
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2008 Ford Ambulance (A47477)
2008 Ford...
2021 WESTERN STAR 4700 DUMP TRUCK (A55745)
2021 WESTERN STAR...
