how does the hyd fluid
   / how does the hyd fluid
HELLO TO ALL,
on the MF 165 cylinder, and control valve.
trying to get the control valve apart, manual says, insert a
pin punch into hole B, (return port) in order to unscrew the
spool. i do not see any hole that lines up with port B, or A.
i appears it might line up with the inside hole that has a check
valve,(ball) but i cannot get the setscrew out. it appears there
is some kind of sealant in this to prevent removal. any ideas?
any comments, appreciated.
accordionman
wlbrown
wright city, mo.
HELLO AGAIN,
i finally found the secret to the control valve,
and now have it apart. thanks
accordionman
wlbrown
wright city, mo.
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
