How does the mysterious floating orb work?
   / How does the mysterious floating orb work? #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I know that magnetism is involved but it is not just magnetism because you can't make an item float with just magnetism. Either it won't move or it will stick to the magnet.
When this is unplugged, the orb won't float no matter how hard you try, but the top of it will stick to the top of the frame because obviously, one has a magnet in it and the other is magnetic. Whether plugged in or unplugged, there is no attraction between the south pole of the orb and the bottom of the frame.
I know some of the wizards on TBN can figure this out and explain it to me
See video at http://youtu.be/ug9AoFTHGzc
   / How does the mysterious floating orb work? #3
Electromagnets top and bottom and when you get in the middle sweet spot where the forces pulling up match the force down, the orb stays put?
   / How does the mysterious floating orb work? #4
https://hackaday.com/tag/levitation/
looking at the few listings that came back. kinda surprised me use of "sound waves" (out side of human hearing) was being used. never heard of such thing before.
a couple other notations were sounding more like "magnetic bearings" or ring magnets.
I know there is no magnet or electromagnet in the base or in the south pole of the globe as I have checked them out well with my good magnets.
   / How does the mysterious floating orb work? #8
If you can do this with a cheap toy, what prevents you from doing it with a flying saucer? :confused:
If you could use a globe or sphere I suspect you could use a saucer instead.....Why not?
Really, until I can build one myself and see it work, I will continue to just believe that it's magic. ;)
And.... by definition, you would not be incorrect.
noun
1. the art of producing illusions as entertainment by the use of sleight of hand, deceptive devices, etc.; legerdemain; conjuring:
to pull a rabbit out of a hat by magic.
Magic | Define Magic at Dictionary.com
   / How does the mysterious floating orb work? #9
Dudley, You are in LA..... It's Voo Doo ! :laughing:
   / How does the mysterious floating orb work? #10
Find out, do a Google search, stop speculating.
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2015 CAT 573c Fellerbuncher Cutter (A48837)
2015 CAT 573c...
New/Unused 44in Mini Skidsteer Grapple (A48837)
New/Unused 44in...
2021 Bobcat T64 Track Loader (A50490)
2021 Bobcat T64...
2014 Dodge Challenger SXT Coupe (A48082)
2014 Dodge...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A50505)
2018 PETERBILT 579...
