How far can you extend a PTO shaft?
   / How far can you extend a PTO shaft? #1
North Country
VT
John Deere 2305
I just bought a tiller from a guy who had it on BX23. I'm putting it on a JD 2305 and the shaft is too short. Not only would it naturally be too short, I have Pat's easy change - which adds 4 in to the required length.
The local TSC sells 3in and 4in PTO extensions. I would probably need two 4in extensions - certainly not less than two. If I tried two, I'd put one on each end instead of stacking them.
How much extension is too much? Any other ideas?
Anyone have a long slip clutch shaft they haven't cut yet and want to swap? I'll pay freight both ways.
   / How far can you extend a PTO shaft? #2
I suggest you buy a replacement drive shaft and fit it as required so you don't need any extenders.
Even a cheap TSP slip clutch shaft is $250...that's an option, but certainly not my preferred one.
   / How far can you extend a PTO shaft? #4
You could look at getting a new shaft from Agri Supply Company. They are fairly reasonable. I had to get a separate pto shaft for the tiller I was running on a Yanmar 2000 since I didn't want to cut the one I was using for the rotary cutter. Found it much more easy that way.
   / How far can you extend a PTO shaft? #5
If the useage for the tiller is not extensive, you could probably use the 2, 4" pto extensions. I frequently use a single extension because I have quick hitch. Any extension creates a bit of slop in the system. I use mine on the attachment side. If you just using the tiller several hours/year, I would go the cheap route of 2 extensions but not stack them.
   / How far can you extend a PTO shaft? #6
Two extensions would be far to sloppy IMHO, you are asking for trouble if you do it.
   / How far can you extend a PTO shaft? #7
Yep..premature wear in the tractor's PTO shaft, bearings and seals...
Turns out the TSC ones aren't usable as just extensions - they're adapters to change shaft size (and also extensions by default.)
This company sells extensions up to 4".
Double HH Quality Products
I'm going to play some musical chairs with my shaft ends to see if I can't get a combination that works on all attachments. I cut my shafts as long as possible - maybe that practice will help me out tonight.
   / How far can you extend a PTO shaft? #9
I got mine from TSC, but I had to go to the store to find one. One thing might help is to search for PTO adapters. They do (or did) sell a 1.375/6 flute female to 1.375/6 flute male (which is what I have and you need). Cost was about 20 bucks. I only use this adapter on my PTO chipper.
When mixing matching those other shafts, just make sure there's no way it can bottom out. That can be destructive to the tractor's PTO.
Agri-Supply has pretty good prices on the full drivelines.
I got a combination that works. Here's the followup question - what's the minimum amount of overlap you want in the shafts? I now have a setup where there's about 3" of overlap when raised; more when it's down and working. I couldn't find specs from any manufacturer on the overlap minimum - all instructions say cut as long as possible, which is what I've always done.
2025 LandHero LDH-HT380 Ride-On Mini Track Loader Skid Steer (A55787)
2025 LandHero...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2016 CATERPILLAR 306E EXCAVATOR (A52705)
2016 CATERPILLAR...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
