How high to cut grass question...
   / How high to cut grass question... #11
yeah, as someone said above, another bad thing is removing the clippings. That's free fertilizer, some of the best fertilizer you can put on a lawn. Crazy that people bag them and throw them away.
Another thing is you can cut shorter in fall than spring - if you cut short in spring you give the weed seeds a nice home. They don't propagate so much in fall.
If you regularly cut high, the lawn will look "fuller". Cutting low requires a lot of fertilizer and water because the grass will basically be on life support.
   / How high to cut grass question... #12
I cut mine as high as the mower will go, which is about 4 1/2 inches. It is mostly fescue and I believe it survives the summer heat/drought much better at this length. Also, taller grass tends to compete better with the weeds and keep them smothered-out IMHO.
   / How high to cut grass question... #13
I cut ours Credit Card height...
about 3 3/8 inches
   / How high to cut grass question... #14
This is my philosophy.. Im cutting around 4.5 to maybe 5" - I hope that helps it make it through a hot, dry summer.. My yard is Kentucky 31...
Brian
   / How high to cut grass question... #15
Brian
Should help a lot - shades the ground and keeps it cooler at that height. Be interested to hear how it ends up working for you.
I care how the lawn looks, in the end, not how far offf the ground it is...
   / How high to cut grass question... #16
Somewhere I have read the optimum height for grass is six inches. No verification on that.
On our town lawn I cut as high as the lawn mower will go [push mower with engine] This leaves lots of room for clippings to fall into and should help keep down weeds. I also try and keep the PH as close to 7 as I can. In any case it looks okay to me.:D :D
2006 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2006 UNKNOWN 16...
2011 EDMONTON TRAILER MFG FRAC PUMP (A53843)
2011 EDMONTON...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
5' S/A CART (A52706)
