How high to set rotary mower?
   / How high to set rotary mower? #11
High and often at first. Once you have it tamed, it depends upon your use of the land and the grass variety you wish to encourage. Western Virginia covers a lot of different soil types from lime rich soils on the eastern border with WV to acid clays in areas adjacent to southern WV and eastern KY. In the former areas Marion Blue does well and tolerates fairly close clip although it thrives if kept close to 3" where it can choke some of the competition. Tall fescue or timothy does well in the areas I mentioned later and should be kept fairly high at 3+ to resist drought an to choke out other stuff. For most grasses, high and often is most healthy especially if cutting with a hog.
prs
Thanks again for all your advice. Prs I'm located a little north of Roanoke, about a half hour from WV in Botetourt County. I am hoping I won't have to re-seed as the field used to be grass. Once I've mowed it a few times I'll have a better idea. Hopefully there won't be too much in the way of debris or rocks as I kept it mowed until 2005. It's amazing how quickly and how tall some trees and brambles can grow in that time, and rocks do seem to appear like magic every spring, so I'll keep the blade high and FEL low as many of you wisely suggest.
   / How high to set rotary mower? #13
Yes that first mowing it can be hard to see what your doing.
One other point. A inch and a half sugar maple sapling bent over and wacked off about eight inches high makes a pretty good pungi stick when it springs back up. Be careful of your tire side walls on second cut and mow in the same direction you did the first mowing.
   / How high to set rotary mower? #14
Don't use sharp blades. They are supposed to be blunt to splinter saplings instead of making spears.
   / How high to set rotary mower? #15
This is the reason I prefer to cut as low as I can to avoid leaving all those punji sticks that later try to hole your tires. I would lower the FEL to about 6-8" off the ground to find those missed items from your walk thru and then go slow enough to thoroughly cut everything at 3" which is about as low as most bush hogs will cut. I mow it with the skids just off the ground.
Cut it all in one pass and then keep it about that height. There is really no reason to cut it at 10" and go back over it later and cut it again as long as you have the HP to turn the mower. I would rather go a bit slower if necessary but cut it low in the first pass.
Edit: just keep the rear raised at least 4-6" higher than the front so all that debris can clear out from under the shredder.
   / How high to set rotary mower? #16
Believe me with the ground I have they weren't sharp very long.
Thanks again for the advice and pictures. Sorry to hear about you still getting snowed on in Vermont vtsnowedin. It is a balmy 66 degrees in our neck of Virginia right now. I'll do the second pass in the same direction as you suggest. I was going to do just the opposite.
   / How high to set rotary mower? #18
Go ahead rub it in why don't you!! Actually it was pretty nice today. sap not running but full sunshine so bare handed work on pipeline repairs was comfortable. I'm down to the small set of snow shoes. The snowpack will now hold up a dog but not my considerable mass without some assistance.
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
2022 Horizon (A55973)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
LOT OF CHICKEN EQ. NEST, BROADER & FEEDER (A58374)
LOT OF CHICKEN EQ...
