How long did your original battery lasted?
   / How long did your original battery lasted?
I don't think OEM batteries exist in Kubota equipment. Dealer installs whatever they want. Could be good, could be cheap. When it's only got a 12 month prorated warranty, it's probably a hint :(
I don't know about other colors.
Ken
Well, on mine,the battery have a Kubota warning label, I really doubt that a dealer would go to the trouble to use an after-market battery and put a factory warning label on it.
My guess would be that all Kubota tractors come with a battery from the factory
   / How long did your original battery lasted? #22
with a solar battery charger connected to it.
The last 4 years the tractor has been inside my garage with a cheap Harborfreight ($5) float charger plugged to it.
These seem like two great ideas to me :thumbsup: Lead acid batteries last longer if they are kept at full charge.
My 2001 L3010 has the original battery still. I make sure that I use the block heater when it is below 10 degrees F (most of the time)
   / How long did your original battery lasted? #23
Mine has lasted a little over 8 years. I noticed that the glow plugs were staying on longer than they used to. Replaced battery yesterday and now the glow plugs come on and go off as quickly as they used to.
   / How long did your original battery lasted? #24
Ken I think you are right that dealers can install whatever they want (same with tires), but there are OEM batteries.
   / How long did your original battery lasted? #25
Any one every try that ETP stuff that is to rejuvanate your battery and make it last longer?
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
2015Carry-On 8ft. S/A Utility Trailer (A55853)
2015Carry-On 8ft...
Standing Metal Firepit (A55853)
Standing Metal...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
flooring (A55758)
flooring (A55758)
