How long do you glow and crank for?
   / How long do you glow and crank for? #31
***"After reading this, it might be better to ask if there is difference between "New tractors vs. Older tractors"??"***
There must be a difference. My 80's B6100 needs the glow plugs on for close to a minute in sub freezing temps. I'd rather run the glow plugs longer than waste the amperage trying to start it multiple times. If I give it enough glow plug time it usually starts the first or second crank. Been doing this for years with no consequences that I know of.
   / How long do you glow and crank for? #32
Art, in post#19 says it well. Do whats needed to get it to fire promptly. Otherwise youll be washing down the cyls and diluting the oil and replacing starters and batteries.
larry
   / How long do you glow and crank for? #33
I have started diesels with glow plugs in cold weather for over 30 years. If the engine starts without the use of the glow plugs...great. Then I don't use them. But you get a feel for each diesel engine. You will learn how your engine starts in cold weather. If it fires on the first crank in zero weather without the use of the glow plugs...go for it. It it doesn't fire quickly don't keep cranking. Stop cranking and turn the glow plugs on for as long as it takes to start quickly. You will soon figure out how long it takes for your engine. As the engine gets older it might take longer but I wouldn't start out using the glow plugs for long periods when the engine is new. Glow plugs are wear items. They are resistance heaters and can burn out when over used.
Tom
   / How long do you glow and crank for? #34
Well, I'm a newbie at cranking an old B6100 engine. Previous owner told me to use the glow plug anywhere from 15-30 sec. So far, with temps below freezing, it seems like 30 seconds will do the trick, might have to repeat it one time, but not more than that.
   / How long do you glow and crank for? #35
My B7100 always takes at least a minute in cold weather but only 15 or 20 seconds in the summer. If t is really cold I also use the compression release to get the engine turning faster, then slowly let up on the release until it starts. Does anyone know if the glow plugs continue to heat when you turn the key from the left for preheat back to the right for starting? I suppose I could check this with a meter, but I thought someone might know.
   / How long do you glow and crank for? #36
Also make a difference how old your battery is...
   / How long do you glow and crank for? #37
In sub zero (Celcius), 30-45 seconds and she goes. In the summer, 10 sec. does the trick.
Eric
   / How long do you glow and crank for? #38
Yep, my b7100 is the same. I really like the lower hose heater I put on though... just need 10 seconds or so when its been plugged in a while and really warmed up. Even just 15 minutes with the heater helps it crank a lot better.
   / How long do you glow and crank for? #39
I checked mine today. The glow plugs are on when I turn the key to the start position.
2015 Wacker Neuson G50 38kW Towable Diesel Generator (A56857)
2015 Wacker Neuson...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
