escavader
Veteran Member
3 0r 4 minutes,but im real gentle for the first 10
ALAN
ALAN
RoyJackson said:I wait until the tractor reaches operational temperature (about ¼ up the scale) if I'm going to work the tractor.
If I'm just moving the machine, I'll idle at 1500 RPM for about 30 seconds before I put it in gear.
Taiser said:If I waited for my temp needle to rise it would be sitting there all day!!!
bx23barry said:It's just a waste of fuel to let anything sit and idle.
Toolguy said:I agree with bx23barry. It will warm up faster if you move it around a little vs. standing still.
Glowplug said:Yeah, I guess it's okay if you guys do it that way. Just don't turn the key, raise the engine speed to 3,000 rpms, put it in hi 4 gear, and pop the clutch so that off you go!!![]()
_RaT_ said:.7 seconds after the starter motor stops spinning.![]()
john_bud said:Try that at -30F with an HST unit..... but have an extra filter and 5 gal of fluid ready!
In spring, summer and fall, it is turn the key start and drive to the place where the work is. That is usually a 2-5 min tractor ride at low speeds.
In winter, I let it run for several minutes with the clutch dogged down then a couple more with the clutch up to warm the fluid but not pop the HST filter. The time of the warm up depends on the temps.
jb
