How long does hydraulic fluid last?
   / How long does hydraulic fluid last? #11
Change the filter regularly if it is running cylinders. On my hydrostatic transmission tractor, I have to drain all the oil to clean the sump screen. I just put new in because it is cleaner. Regular recommended is 400 hrs. I went 500 with no problems.
   / How long does hydraulic fluid last? #12
On my gear tractor the recommendation is to change just the filter at 50 hours then go to 1200 hours before changing the oil and filter again. (and clean the screen) Hydro transmissions would probably be more often. I can tell you if you get water leaking into an open center system the oil will look milky. At ten gallons per change doing it more often then called for gets hard on the wallet.
   / How long does hydraulic fluid last? #13
My 3930 only gets about 60 hours per year nowadays. The manual says something along the lines of 600 hours. I change both hyd filters ( optional hydraulic pump ) about every 125 hours; between the loss during filter changes, the occasional blown line, and loss from a leaky cylinder here and there I add about 2 gallons a year. The oil looks like the day I bought it and all hyd stuff works fine. Gear transmission.
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
John Deere 6120E (A50323)
John Deere 6120E...
1997 Equipment Trailer, Dual Tandem Axles (A52384)
1997 Equipment...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
