How long does it take to rebuild an MF35 hydraulic pump?
   / How long does it take to rebuild an MF35 hydraulic pump? #1
cockeyedMFer
1959 MF 35 deluxe, gas
I've got a broken piston in the internal pump. Debating whether to buy a rebuild kit, or a good used pump from a local dealer. Difference is about $70. I'd prefer to do it myself but don't want to have the tractor down too long. Is it a couple hour job once the pump is removed?
   / How long does it take to rebuild an MF35 hydraulic pump? #2
I guess the big question would be, what else is damaged and would the "rebuild kit" include all the parts that could be damaged. Most piston pumps I am familiar with usually have other components damaged when a piston brakes.
Roy
   / How long does it take to rebuild an MF35 hydraulic pump? #3
Rebuilding your MF pump is straight forward for one with reasonable mechanical skills.
Myself, I would NEVER take the time to R & R the pump without properly rebuiding it myself. I would NEVER install a "good" used pump.
Do not expect to rebuild your pump in two hours unless you have done it before.
Dean
   / How long does it take to rebuild an MF35 hydraulic pump? #4
G,day Mr cockeyed.
The Massey Book time is six hours that is Shop time for a standard transmission tractor i,e the tractor in the workshop lift cover removed, pump stripped and overhauled ,refitted and both internal and external adjustments completed.
There are a few things that can add time to the job ,one is cleaning If you decide to send the tractor to the shop make sure it is spotless clean.
If the tractor is Multipower It will take about 10 to 12 hours to split the tractor to remove the both pumps.
I would heed the advice of SDT and oldnslo Both should be considered and definitly replace EVERYTHING that needs to be replaced.
Happy days .
Hutch.
Guess I'll have to bite the bullet and do it properly then...With winter coming on I can lay it up inside and take my time, but still it seems like every time I think about tearing into it, the next day I need the bucket for something.
Oldnslo - the kit most vendors sell has pistons, valve blocks and o-rings. Would like to know what broke the pistons though before overhauling it.
Shona - its a 35 deluxe, so fortunately no multipower!
   / How long does it take to rebuild an MF35 hydraulic pump? #6
Cockeyed,
I can not look at the parts breakdown on the AGCO sight for reason so I am uncertain as to style of pump on this model. Is it a radial piston or axial piston?
Axial piston: the pistons run parallel to the drive shaft Usually what breaks on these is the slippers. When these break they usually destroy a wear plate on the swash plate and send metal filings into your bearings etc. Causes can be from excess speed, sudden pressure changes, case pressure higher than inlet pressure, preload spring(s) broken or fatigued from old age, heat etc...
Radial piston: I am not as familiar with but would suspect over speed, or over pressure could break them. Depending on what loads them against the cam this could also have broken causing it to knock.
good luck and keep everything very clean during reassembly.
Roy
Here's a diagram - I'd call that a radial piston? Its driven by a 2-lobed camshaft that runs in line with the transmission shafts (not picured)
The square piston frames are thin cast iron, and cracked in half.
   / How long does it take to rebuild an MF35 hydraulic pump? #8
The MF pump is a scotch yoke pump. Breakage of the piston yokes is usually caused by debris in the oil.
Comprehensive kits include the yokes and brass parts. Inspect the champers for damage and wear. These are not included in the overhaul kits and cannot be inspected until the pump is disassembled. Thoroughly clean the valve chambers of sediment and debris. You will no doubt spend more time cleaning than repairing.
Be CERTAIN to thoroughly clean the sump including the differential sump while the pump and PTO shaft is out.
SDT
   / How long does it take to rebuild an MF35 hydraulic pump? #9
I know this is a fairly old thread, however, I've got the same tractor and problem...MF 35 Diesel...my three pt wont come up...I assume the hydraulic pump is "out"...do you have to split the tractor to remove/repair/replace the pump ? Not a show stopper as I also have another new tractor...I evenutally want to restore to "factory new", my MF 35 was given to me by my father and I want to evenutally give it to my son...family heirloom so to speak...
Rich
I still haven't repaired mine yet, so its still a topical thread LOL.
There are some how-to videos on line, but basically you lift off the top of the transmission (under the seat), unbolt the oval caps on the outside of the transmission (left and right) and remove a splined shaft that drives the pump.
It will lift out the top of the trans.
In my case, I think water got into the trans, froze, and cracked the cast iron pistons when the tractor was used in cold weather.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2021 VOLVO VNL740 TANDEM AXLE MID ROOF SLEEPER TRUCK (A57880)
2021 VOLVO VNL740...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
