How long does it take to repair a clutch and piston a John Deere 955 ?
   / How long does it take to repair a clutch and piston a John Deere 955 ? #1
joeSmith955
john deere 955
How long does it takes for a professional tractor mechanic, with access to a full-set of tools and a lift to dis-assemble the transmission, remove the front gear case cover, replace the clutch, clutch plates, snap rings, clutch springs, and piston. and last re-assemble everything? 1day, 2days, 3days 4, 5?
Thank you
   / How long does it take to repair a clutch and piston a John Deere 955 ? #2
based on the information provided the answer is YES.
   / How long does it take to repair a clutch and piston a John Deere 955 ? #3
Welcome to TBN
JD dealer service managers has access to a labor flat rate manual that should contain the info you're seeking.. IMHO having served as a JD dealer service manager for 13 yrs you left out way too much info pertaining to your tractors required repair for anyone to accurately answer your questions.
   / How long does it take to repair a clutch and piston a John Deere 955 ? #4
I agree, much more info is needed...
SR
Welcome to TBN
I just want to get a general. What other informations do you need? Thank you.
   / How long does it take to repair a clutch and piston a John Deere 955 ? #6
Not to specifically address your question or concerns, but several years ago, my son was a part of the crew for the viper number 93 in GTLM racing. The driver radioed in that he was having traction issues. They had him come to the pits for tire change. If I remember correctly, this was at Sebring.
Well they found the drive lugs (my term not theirs) were faulty. These are what we would call lug studs, but for them there us 1 lug nut in the center thin drive lugs or pins. They changed out both drive hubs and put the car back on the track. They also ran the 91 viper on the same team but separate crew, brought it in and found the same damage occurring. Performed same repairs. Long story shorten, both cars came out of that race due to a batch of improperly hard lugs.
Bottom line with a near 30 year tractor, you never know what you will get into when you start such a project. Some of those issue would be factor into a shop hour estimate, but......
   / How long does it take to repair a clutch and piston a John Deere 955 ? #7
on a car or truck, 1 day at most.. certain tractors may take a bit longer to get things removed, but it's easy once it's in an easily accessible bench..
   / How long does it take to repair a clutch and piston a John Deere 955 ? #8
Regardless of the time to accomplish the repair, you also have to figure in the dealers backlog and where you are in his list of priorities. If it is harvest time you have to expect his big customers in the middle of harvest will get priority. Curious as to why you are asking this question here. Why not just ask the place where you are having the repair done?
Doug in SW IA
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2019 Ford F-450 12ft Utility Flatbed Service Truck (A55788)
2019 Ford F-450...
