How Long is Sitting Without Running OK?
   / How Long is Sitting Without Running OK? #11
IMO it is probably better to let it sit. Pull the battery and put it on a battery tender than to keep starting it for a short time. Here's my reasoning unless you are going to run it at a decent rpm the motor won't come to full temperature and you will get condensation done in the oil. With diesels this will create sulpuric acid (even with ULSD fuel) which will over time damage parts. What I would do is when done for the year change engine oil check and make sure all fluids are full and not contaminated. pull battery (or just disconnect if inside) and place battery on charger (tender). Wait until next spring hook up battery and go. Letting a tractor sit for long periods won't hurt them. If tractor is outside and you want to keep it looking newer cover with good quality tarp.
Good luck.
   / How Long is Sitting Without Running OK? #12
I have a mid '90's b series (gear) Kubota...
This tractor came with a small block of wood to use on the clutch pedal bar to keep the pedal depressed and the clutch disengaged whenever the tractor is to be stored for more than a few weeks...
   / How Long is Sitting Without Running OK? #13
Good Point :thumbsup: Mine has a hook on the floorboards to hold the clutch petal down for "Long storage Times" which is not defined.
gg
   / How Long is Sitting Without Running OK? #14
I've been reliable about starting it and running it warm at least once a week, and I've no problem continuing this.
My question, and perhaps it will help others as well, to those who know:
Is starting and driving it to full temp once / week enough, too often, or not often enough to keep everything lubricated and cleaned out (journals, etc.)?
Thanks,
gbw
It depends on your location and the weather. Just starting it and getting it "sort of" warm once a week is a sure fire way to cause a boat load of condensation to form inside the transmission, hydraulics and engine in cold areas. Maybe not so much down south. Rule of thumb for me is to NEVER run the machine for less than an hour. Especially in the winter. The moisture in the fluids needs time at temperature to get out.
Others may differ, but I would strongly advise you to only start the machine when you are going to USE it and then run it HARD for at least an hour to get the fluids to dry out. Otherwise, you will cause troubles not fix them.
FYI - yesterday I took off the cutter and put on a back blade in anticipation of snow. That was the first time the tractor had been started since early October. The battery in that machine is original from either 1999 or 2000 and it starts up fine when I turn the key. Other tractors haven't been started since August.
   / How Long is Sitting Without Running OK? #15
My dozer often sits for months or longer without any prep what so ever.
   / How Long is Sitting Without Running OK? #16
X 2. Start it and run it only when you need to use it. There have been/are literally hundreds of thousands tractors and combines, harvest equipment, haying equipment, and even large construction equipment that sit for months on end without starting and it doesn't hurt them one bit.
   / How Long is Sitting Without Running OK? #17
My father who was a mechanic had learned to start up the army trucks every 30 days and move them the lenght of them selves. In keeping the trucks stored in a bumper to bumper fashion only the first and last could be stolen. Second when you exercised the fleet the line only became 1 truck longer and 1 truck shorter.
Craig Clayton
   / How Long is Sitting Without Running OK? #18
If you do start and run, get her hot!
That way you 'boil out' any water vapors that are in there.
Those condensed vapors are what will cause internal corrosion. (rings and cylinder walls will suffer the most)
Also I understand that in some cases acids can form that could etch metals.
Damp, humid air can always enter via the intake manifolds=corrosive conditions.
Some clutch tractors (Mitsubishi) can end up with the clutch face corroded to the flywheel. The advise here has been to install a wood block to keep peddle depressed.
Some actually have a hook to hold the peddle depressed.
Now, let's not get carried away. Couple of weeks, even a month will probably not cause any harm but longer, well, if for nothing else run her to charge up the battery.
Start her and go have a coffee or a cool aide!
   / How Long is Sitting Without Running OK? #20
I've never had many problems with machines sitting, The combines sit in a shed idle from november to july every year and most of the tractors sit for 4 months too , And the swather only works 2 months of the year ..never any trouble.
One that interests me is my neighbour has a MF 3690 fwa which has been sitting for 8 years without moving since he sold his farm , I would like to see how that behaves when it next moves ?
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
2020 DRAGON ESP...
