How long should a dry clutch last?
   / How long should a dry clutch last? #11
So it depends on how you treat it.
OrangeGuy )</font>
And knowing how to treat it.... Like I said...so many people dont know or belive it. I will admit...it is easy to do if you are not paying attention.
Ronald
   / How long should a dry clutch last? #12
So with all this "proper use" talk going around, what is the best method to use for picking up a pile of dirt with the loader? Is it OK to slip the clutch so that u can stay up against the pile without breaking traction? or should you drive in, brake and lift??? The problem with the second is that you (I)cant use the foot throttle to increase lift speed while braking. Suggestions?
   / How long should a dry clutch last? #13
1800hrs r&r on mine, with frequent heavy loader use. This is organic, not button clutch which last longer but are hard on flywheel.
   / How long should a dry clutch last? #14
Definately do not slip the clutch to stay close to the pile. At higher revs (to lift and scoop) you should be using the hand throttle to give you the appropriate power, and the brakes to hold while pressing the clutch in (I use my left hand to swtich gears back to reverse at the same time).
While digging in to fill the bucket, select a lower enough gear, moderate throttle and scoop into the pile with a level bucket. BEFORE bogging down or spinning the tires do the following: clutch and brake, curl, lift and back out.
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
