How long will heating oil last?
   / How long will heating oil last? #11
just curious how your Father worked in the garage for 10 years without power?. if the heater is a Boiler, the water must have frozen and cracked the boiler and lines years ago..
Forced hot air doesn't require water. The power was tied into the greenhouse which they had turned off when the power bill got ridiculously high even though it was barely getting used. I believe that he drained the water out of the greenhouse boilers years ago when he installed another hot air system there, before he started forgetting things.
Old age sucks. :thumbdown:
   / How long will heating oil last? #13
"the water must have frozen and cracked the boiler and lines years ago"
Ya think?
Isn't nontoxic antifreeze used in hot water systems on Long Island?
I have a house in New England, and another in Canada.
Both boilers/lines are shut down all winter, with never a problem.
   / How long will heating oil last? #15
Ya think?
Most boilers are just straight water, with an auto fill line for makeup water.
Some, a few will have an anti-freeze solution in them.
   / How long will heating oil last? #16
Thanks for the replies. It sounds like the first thing that I need to do is get some of this; Gasoila All Purpose Water Finding Paste, 2 oz. Tube at Tractor Supply Co..
If you do use the paste, when using it in distillates (heating oil, diesel) best to let the stick sit in the tank for a minute or two -paste sometimes gets coated with the heavier fuel and will not react as quickly as it does in gasoline. I would worry about the integrity of that outdoor tank as much as anything-was it shielded in any way from rain and how far off the ground is the tank bottom?. Assuming it is on typical pipe legs, make sure there isn't a lot of corrosion where the legs screw into the brackets that are welded onto the tank.
2013 Club Car Turf Carryall (A50121)
2013 Club Car Turf...
2010 John Deere 648H Grapple Log Skidder (A50322)
2010 John Deere...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A50322)
2023 Caterpillar...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
