How many hours on your L3400
   / How many hours on your L3400 #21
1300 hours on my 2007 hst but it has been abuse quite a bit
-pto cable broke twice (changed the whole system wo/ a cable
-front axle leaked bu that isnt a real biggie
-no problems with the 3pt
-the piece that attaches the front wheel drive shaft from the back(under where the operator sits) has worn out twice now, cant figure out why though
I have been thinking about that. One thought I had is to do it with a linear actuator so I can turn the PTO on/off with a switch. I'd use a two pole switch so the other side could close the interlock. I did this on my fertilizer spreader. I'd like to see how you did yours.
   / How many hours on your L3400 #23
315 hours on my 2006 DT. As far as repairs, I had to replace the Hydraulic suction hose, one turnbuckle for the 3PH and I have a hydro fluid sight glass ready to go in because mine is leaking. Still the original battery. I did bump up the hydraulic pressure to about 2650psi and haven't seen any problems because of it, but I also added the backhoe at around the same time, so I have plenty of ballast in addition to the loaded rear tires.
We use the Wallenstein skidding winch to harvest about 30 full cords of firewood to heat 3 homes every year. It's been a great tractor all in all. I plan on adding another tractor in the next year.
   / How many hours on your L3400 #24
I dont have the 3400 but an '08 2800 dt and its done nothing but work and work hard, best equipment i have ever owned, only thing ive done is keep it greased and the fluids changed. Just turned 260 hours this weekend.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
207274 (A52708)
207274 (A52708)
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
