How many hrs do you get till you have to refuel
   / How many hrs do you get till you have to refuel
Thats good to know guys. Thanks for the help.
   / How many hrs do you get till you have to refuel #12
I only began to monitor fuel use at hour 56 but in the 39.5 hours I've run since, I've put in 31 gallons and still have something around a third of a tank left.
   / How many hrs do you get till you have to refuel #13
my brother has a l4330 gst and a m9000 . we call the 4330 the hog because he can only get 5 to 6 hours out of a full tank. where as the m9000 will run for days. now i know that the big bota has dual tanks and holds more fuel. so he conducted a little test where he ran them both out of fuel, and refilled them with 5 gallons of fuel using the same jug and sure enough the big bota ran almost twice as long on the same amount of fuel. after reading about the fuel economy of the tractors here, maybe his needs a service call
   / How many hrs do you get till you have to refuel #14
I have a 4630 and average 1gph including start up and travel time. When bushogging at rated pto it would be between 1.25 and 1.5 gph.
   / How many hrs do you get till you have to refuel #15
I've been pleasantly surprised that I also tend to get about one hour to the gallon with my L3130, and even better running slower than pto rpms. It is vastly superior to my gas lawn tractor.
My fuel gauge has also been more accurate than any car that I've owned. It drops at the same steady rate from full to empty, unlike most cars that seem to show full tanks the first 200 miles, then suddenly drop to Empty over over the last 100 or so.
   / How many hrs do you get till you have to refuel #16
If you engage the mid pto and throttle up for a few hours (snowblowing,sweeping,etc) you will see a big time increase in fuel use. B3030hsdc/403fel
   / How many hrs do you get till you have to refuel #17
as mentioned it depneds on the task at hand but about 1 GPH is a good guestament.
But now that winter is here and the Kubota sleeps outside as we sleep in the shop, as the house is being built. I try to keep the tank almost full all the time. There is so much humidity and temperature changes I don't want to get water in the tank and start to grow microbes.
steve
   / How many hrs do you get till you have to refuel #18
Think the answere may lie blowing on the load! /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
Survey Kit (A53316)
Survey Kit (A53316)
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
230112 (A53422)
230112 (A53422)
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
