I am going to be building a 3pt ballast box and need a little help in "how heavy" I should make it.
I have an '00 JD 4200 with 420 loader. The tires are not loaded - avoiding that if possible.
My plan is to build a form box and then fill w/concrete - a variation of some ideas I have found in the forums.
Depending on the needs - I can vary it from 500lbs on up. Due to design constraints my upper limit is around 1,100lbs. (I could always work around it if needed).
Any recommendations?
As a secondary question - I have calculated out that 1 lb of concrete is approximately 7.2 cubic inches - can anyone confirm I'm close?
Thanks all!
Kerry
Thanks all!
Kerry
