How much does a BX-25D weigh?
   / How much does a BX-25D weigh? #1
valkyrie9901
Adrian, Michigan
Kubota BX-25D
Was wondering the weight of a BX-25D as my trailer has a capacity of 2340 lbs.
How do you rotate the pic? It was right when I uploaded it.........JB.
   / How much does a BX-25D weigh? #4
I am of no help. I have noticed several other attachments that were rotated in the last day or so. It may be a forum-wide problem. You could try reloading the photo.
Steve
   / How much does a BX-25D weigh? #5
   / How much does a BX-25D weigh? #6
Pretty sure that's the weight of the tractor less the FEL and BH...Guessing the whole thing goes around 3k give or take.
EDIT: The answer from Messicks in another thread:
Tractor - 1600
backhoe - 700
loader - 400
= approx 2700 lbs.
That makes sense.
Steve
   / How much does a BX-25D weigh? #7
I live right beside the local sand and gravel yard, so I weigh pretty much anything. So with me sitting on my bx 25d it weighs right at 3000 pounds. So that puts the tractor + loader and backhoe and loaded tires at 2800 once you subtract my body weight. These scales are very accurate. They are calibrated every few months.
   / How much does a BX-25D weigh? #8
that makes sense, as the messicks numbers quoted above may be dry (w/o fluids)
   / How much does a BX-25D weigh? #10
Loaded tires might be in the equation too
METAL SHOP TABLE W/CONTENTS (A55745)
METAL SHOP TABLE...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A56129)
2008 AAR MOBILITY...
CASE 610 Sprayer System 2000 Gallons (A55302)
CASE 610 Sprayer...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
