How much does a round bale weigh?
   / How much does a round bale weigh? #11
Egon,
I always hated putting them on the hay elevator.....darn elevator could not hardly get the bale up in the barn...bad enough to put them in the manger....had to jump up and down on it to get it to fit..../w3tcompact/icons/laugh.gif
<font color=blue>""I just unloaded one from the back of my truck. I was wondering if the weight could be too much for my FEL? "" </font color=blue>
<font color=red>If you unloaded it with your FEL, then would you please tell us what happened. If nothing broke, and the rear wheels stayed on the ground, then the weight isn't too much for your FEL, IMO.
If, however, you didn't unload it with your FEL, then I understand the question. What did you unload it with?
</font color=red>
Well I did use my FEL with forks to unload the bale. I had to use two chains to stretch around the bale to keep it from falling. It worked well and didn't lift the rear wheels. However, I used the mower (700 lbs) as a counter balance.
I backed down the hill and dropped it right where my wife wanted it.
   / How much does a round bale weigh? #14
There is an article in the "safety forum" about a man getting hit by a 900# hay bale. I would assume that to be a standard size round bale.
   / How much does a round bale weigh? #15
The "standard" sizes seem to be between about 850lbs and 2000lbs. depending on baler. a 4ft wide bale is gonna be on the lower end, and a 6ft bale on the upper end...
Safety note, never attempt to move a bale without either forks or a grapple type bucket. Many have been killed trying move bales with a dirt bucket.
   / How much does a round bale weigh? #16
<font color=blue>never attempt to move a bale without either forks or a grapple type bucket</font color=blue>
Scott, I've moved several round bales with my B7100 and even a few with my B2710 using the bucket on the FEL. I just lowered the bucket almost to the ground, eased it up against the bale, then eased forward while at the same time, slowly raising the bucket, and rolled them along until I got them where I wanted them/w3tcompact/icons/laugh.gif No way you were going to pick them up with those little tractors./w3tcompact/icons/laugh.gif
   / How much does a round bale weigh? #17
Perhaps I should have said carry... /w3tcompact/icons/smile.gif
   / How much does a round bale weigh? #18
But you'd better make sure you're on flat land, Bird! I have a friend who moved round bales like that, until one accidently rolled down a hill, and took out part of a fence on the way down!!/w3tcompact/icons/shocked.gif But of course, knowing you, Bird, I'm sure you made sure that there were no hills for it to roll down!!/w3tcompact/icons/clever.gif
   / How much does a round bale weigh? #19
I'll bet that was fun to watch, Rich, as long as you weren't involved./w3tcompact/icons/laugh.gif
   / How much does a round bale weigh? #20
Nope, I wasn't involved!! I've done a lot of dumb things on the farm, but that wasn't one of them!!!/w3tcompact/icons/hmm.gif
But, I sure wish I had seen it happen!! I saw what was left of the fence, and that bale reduced it to splinters!!/w3tcompact/icons/laugh.gif
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
