How much gear oil
   / How much gear oil #11
Agree, about half up on gear box or a tad less. Too full might cause it to start leaking from seals.
Gear oil does wear-out. Should be drain on bottom of box.
prs
   / How much gear oil #12
There should be a set screw about half way up the side. Remove it and fill with oil until it runs out that hole. Then I would reinstall the screw and add a little more oil just for good measure,
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
