How much HP to pull LPGS?
   / How much HP to pull LPGS? #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
Just wondering how much power a LPGS takes compared to a box blade or other implements. I've got a Kioti DK50SE with HST (about 49 HP), and I wonder how big of a LPGS it would handle. 8 foot, 10 foot, 12 foot?
My Gannon 6' box blade gives my tractor all it wants and, in the right conditions, can stop the tractor dead in its tracks. But I know a LPGS doesn't take nearly as big a bite as a box blade can, especially a beast like my 1100 pound Gannon.
   / How much HP to pull LPGS? #2
This is just a guess as I don't have one, but I would say you would be good with an 8 footer. But they weight quite a bit and have 2 sets of blades, sooo.. I would not think 10 or 12 foot would work. Again no experience here, just logic.
   / How much HP to pull LPGS? #3
I have a 6 footer Land Pride with scarifiers.
   / How much HP to pull LPGS? #4
I easily pull my Land Pride GS2584 with scarifiers with my Kubota. Cost and immediate availability kept me from getting the GS2596.
Now that I have the 7' grading scraper - I'm glad I did not go bigger. I would have had real difficulties using it on a couple of the sharp & twisty trails I maintain on my property. It still is quite a bit of attachment swinging around out back. Its not the weight, its the total size that sometimes bangs around off the bigger trees along side the trails. One thing for sure, all my trails are now at least 7' wide!!
   / How much HP to pull LPGS? #5
Just like everything, everything is relevant. Can you pull a 12 footer, absolutely. If and I say this jokingly, if you could find one that weighed very little, maaaaybe about 600lbs, you might be able to pull it. If you were to get a heavy unit that weighs 200lbs per foot width, a 6-7 footer is all you can handle and actually work it.
To give you something to refer to, I have a 5 footer that weighs about 800lbs, I pull it with my 5000lb 32HP Mahindra 3215 HST. It is a very good match IMO. Heavy enough to work well and is what I consider about the max that I can really work with the tractor. I have a 7 footer that weighs 1400lbs. I pull it with my 12,000lb 75hp Mahindra 7520. Maybe, I could get by with an 8 footer, but the 7 footer has no problem stopping the tractor with all 4 tires spinning.
Another example is, I sold a hydraulic top link to the Goodyear proving grounds down in Texas to use with their 180hp John Deere tractor that they pull a 10 foot Road Boss LPGS with. This is a tractor that has probably 5-6 times the pulling power of your tractor and they are only pulling a 10 unit, but it is a very heavy unit.
So everything is relevant. In my opinion, your tractor is good for a 1200-1400lb unit that is 6-7 foot wide. If I was purchasing for your tractor, I would be looking at the heaviest 6' unit that I could find.
Something else that I always find odd is that so many people figure that these things don't move any dirt. If the ground is moist, I have no problem moving well over 3 cubic yards of earth. That is a little bit of weight in itself not even considering the drag that it puts on the tractor.
Good luck with your search and your decision. ;)
   / How much HP to pull LPGS? #6
Oh wow, there is a lot of dirt in there!.. No wonder it takes a horse of a tractor to pull an 8 foot. Thanks for the info.
Thanks for all the replies. I figured an 8 footer would be the max, and that a 7 footer would be a better match. I just saw a 12 footer on craigslist here, and it set me to thinking . . . . which is always a dangerous thing.
   / How much HP to pull LPGS? #8
I can just see you now with your new 12 footer, all 4 tires spinning in the dirt, and not moving an inch. and a sad look on your face!:laughing:
   / How much HP to pull LPGS? #9
Pappy a 6' heavy duty would be a good fit with 6' skids imo. I pull an 8' but it is a real load to do so when it fills up with dirt (about 2 yards).
   / How much HP to pull LPGS? #10
But for the first couple of feet, it should work. So Pappy will have bragging rights with the 12 footer. :)
Unless you'll be working mostly on wide flat roads, I think I'd stay with 7', maybe 8' max, for the maneuverability factor, if nothing else. A neighbor offered to give me a medium-duty 8' box blade for our approx. 1 mile of stone driveway. I played with it for a couple of weeks. My 45 hp NX4510 pulled it quite well full (would start to lose traction on 15% grade), so that size in a landplane/grader should be easy for a DK50. But it made it much more difficult to maneuver, even though my rear tread width with Triton R3s is already 82". Opted for a 7' Woods BSM84, and it is a delight to use.
Cushman Club Car Golf Cart (A55853)
Cushman Club Car...
Rooster Artwork (A55758)
Rooster Artwork...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2014 Jeep Patriot SUV (A55758)
2014 Jeep Patriot...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
