How much plow for a Kubota L 3130DT?
   / How much plow for a Kubota L 3130DT? #1
sparkkky
Oklahoma
Kubota B21
Looking at Kubota L3130DT's and am needing to know what size plow how many bottoms on my mostly sandy soil?
   / How much plow for a Kubota L 3130DT? #2
You got R1 or R4 tires? BobG in VA
R1
   / How much plow for a Kubota L 3130DT? #4
sandy soil; you can probably get away with 3 bottoms.
   / How much plow for a Kubota L 3130DT? #5
Even with sandy soil, I'd go with a 2 bottom vs. a 3 bottom. Old rule of thumb is one HP per inch of plow. If you have 25hp at the drawbar you could handle 2x12=24hp. Even if you had 40 hp you need the weight to pull over 2 bottoms as well. If you can find a good old ford 101 3 bottom, you can try it and then take off the back bottom and have a 2 bottom. BobG in VA
   / How much plow for a Kubota L 3130DT? #6
</font><font color="blue" class="small">( Even with sandy soil, I'd go with a 2 bottom vs. a 3 bottom. Old rule of thumb is one HP per inch of plow. If you have 25hp at the drawbar you could handle 2x12=24hp. Even if you had 40 hp you need the weight to pull over 2 bottoms as well. If you can find a good old ford 101 3 bottom, you can try it and then take off the back bottom and have a 2 bottom. BobG in VA )</font>
I gotta agree with what Bob stated. I have both a three bottom and a two bottom plow. I think the two bottom is a 2 by 16" and the three is a three by 14". Based on the soil in my area (yours may vary - mine is mostly hard clay), a two bottom 14" plow would be a pretty darn good match.
   / How much plow for a Kubota L 3130DT? #7
I agree with all the previous posts,a 2 bottom would probably be your best bet or like mentioned try a 3 and take off one if you need too. I pull a 3 bottom in pretty heavy soil with no problem with 55HP , it is not only the HP it is also getting enough traction, I will have to go to 4wd if soil is a bit wet etc..
If your tires are loaded , sandy type soil ,you just might be able to use a 3 bottom but I wouldn't bet on it.I would look for a good 2 bottom if it were me .
   / How much plow for a Kubota L 3130DT? #8
You will be a able to pull a 2 bottom 14" plow in sand with ease. It will be a struggle to pull 3. Also, the weight of the 3 bottom will require extra weight on the front end of the tractor. Your 32 HP tractor really isn't enough for 3 bottoms. Even in sand it still takes power.
New Idea Manure Spreader (A50515)
New Idea Manure...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
