How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #1
jpilk99
Bolton, MA
1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
The machine runs on starter fluid, quite well, but dies immediately once it's gone. I've cleaned the old carb, tried a new one, swapped fuel line, confirmed gas is good... Checked compression and getting just a hair over 60psi after 3 pulls. Is that my issue, poor compression?
Thank you,
Jay
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #2
Sounds low to me. I only know Honda’s and once they get below 90 your shady, below 85 is a rebuild.
Thank you. And just to confirm, “rebuild” means what to you? Piston, rings, head gasket?
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #4
With compression release you cannot get a usable psi that equates to anything important. Did a generator years ago that showed less than 10% of cylinder leakdown test but only showed 5 psi on the compression gauge. Generator ran fine after determing it had a clogged muffler.
So with some engines 60-70 psi are not unusual. @sea2summit Honda list around 70 psi in a lot of their service manuals for minimums.
To the OP what is the full model type of that engine for reference.
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #5
This $30 leak down tester is really handy from Amazon if you're going to work on motors. It tells more than compression test.
I assume you installed new spark plug and have good spark?
Thanks all. Complete B&S engine details are below. Spark plug seemed good (I cleaned it and reinstalled after testing and it showed good spark; can easily get another). Thinking I might check valve lap?
Briggs and Stratton 128T05-5123-B1​
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #8
I would check valve clearances to see if they have tightened up. Not sure what they should be would guess around .008 -.010 for exhaust and .006 - .008 for intake. Also watch as turning engine over on compression stroke to see if one of the valves is bumped open. This is how compression release works on some models.
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #9
Mechanical compression release on exhaust valve Looks like .005-.007 for intake and .007-.009 for exhaust.
   / How much PSI should a Briggs & Stratton 190cc walk behind lawn mower engine have #10
If there isn't a problem with the intake tube, it's still most likely carb related. Best thing to do is pick one of your carbs, remove the bowl, flip it over and look at the float level. The problem with aftermarket carbs that I've seen, is that they use brass inserts for the float valve seat. And the level is low. In fact, I had bought a couple of OEM carbs on stock up. One of those wouldn't run as the seat wasn't pressed in far enough- thus lowering the float level to something that wouldn't run. If you fix your old carb 398188 is the float valve kit.
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
John Deere 5055E (A53317)
John Deere 5055E...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
Gulf Antique Fuel Pump Art (A55853)
Gulf Antique Fuel...
