Mowing How much pto Hp is needed for a 48" brush mower?
   / How much pto Hp is needed for a 48" brush mower? #11
Just depends on how slow you want to go. If you want to crawl along in lowest possible gear, you can do fine with MUCH less than 5hp per ft.
I have seen people use 6' cutters behind old wore out N-series fords that probabally only mustered 20-21 PTO power. (they were 23 when new and fresh). So that is just a tad over 3hp per ft.
Using that ratio, 13-14hp would equate to about the same.
Curious why you are asking though? do you have a particular tractor in mind? Or just shopping?
The OP's profile lists a Shibaura SU1540. I don't know if this is the tractor he is intending to use. My research shows that make and model has Engine HP-18 and PTO HP-15.
   / How much pto Hp is needed for a 48" brush mower? #12
If that is the tractor, then think a 48 would be okay, but not optimal. I would see about a 42" model as a better fit.
   / How much pto Hp is needed for a 48" brush mower? #13
i've ran a 4' hog on a ford 1210 before... that's low teens hp.. and you must slow down.. but it will do it.
i have some low 10-13 hp tractors that run 4' mowers... etc..
Thanks for all of the replies and opinions. Good info all around.
Yes, I am intending to use an SU1540. My understanding is 18Hp engine, and 15Hp PTO. First and foremost I'm buying it to use on our little urban homestead. However I would like to be able to hire out and make the little beast pay for itself. If I have to charge less per hour than a guy with a 50Hp tractor for brush mowing, so be it. I just want to recover a little of my cost.
   / How much pto Hp is needed for a 48" brush mower? #15
15 pto hp will run a 44-48" mower.. i'd get a kk xb model with 2 tail wheels. make groundspeed match cutting density so she does not stay lugged. scut's generally have oddles of tranny / groundspeed options so this should not be an issue..
Sound advice from a sound guy. Sorry, I'm sure you've heard that before. I couldn't resist.
The 5Hp-per-foot rule is good to know. It's also good to feel fairly confident in pushing it a little if I go slow. I don't mind going slow. I really quite enjoy the sound and feel of a diesel machine working as intended. Having a job take a little longer is almost a plus.
I pick up Shiba this weekend. ****, it has been a long week!
Cheers,
Chris
   / How much pto Hp is needed for a 48" brush mower? #17
I ran a 4-ft King Kutter brush hog with a Kubota B7510HST (17 hp pto) with no problem in 2-3 ft weeds. Just needed to keep the ground speed under control to keep from lugging the engine too much.
   / How much pto Hp is needed for a 48" brush mower? #18
You could buy a little bigger tractor to ran the 4 footer a case 245 or 255 or 265 they are compacts
Yeah, there's always an advantage to having a tractor that's just a little bigger. With all of the new and used machines that are available, I can buy tractors in 1Hp increments. It's really easy to get out of control.
I have hard limits in physicals size, weight, and cost. While some older Ford, IH, and Case tractors are cheap and more powerful, they are universally too heavy. I have a 1ton trailer and no desire to get a bigger one. The newer Kubota and Deere tractors are compact and powerful, but they are far beyond my reach financially. You get the idea.
That's why I settled on a little grey market tractor. I can pay for it with cash, haul it on existing equipment, and store it in my existing garage. While I have yet to confirm, I believe it is equivalent to the Ford 1200. Theoretically, parts won't be too hard to get.
   / How much pto Hp is needed for a 48" brush mower? #20
If you hoping a 15 PTO HP tractor will pay for itself with a 4' mower I wish you luck. It sure wouldn't around my area. When you say a 1 ton trailer I don't see how any tractor with a mower could be hauled and meet the weight limits. Maybe I misunderstood.
MarkV
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
