How much space for tire chains required?
   / How much space for tire chains required? #11
I have my 5045d set to the widest setting with 16.9 x 28 R1's and a set of logging chains. They have about 2-3" clearance on the inside. As Vtsnowdin said, make sure they're nice and tight, and you should be good. I put a couple bungee cords in an 'x' on the outside of the wheel on the main chain, good and tight so that if any slack is to be had, the extra ends up there rather than beating the fender.
Sent from my LGL35G using TractorByNet
What do you mean by widest setting? How hard is it to change setting? Tractor spends most time in woods. Carefull as one tries, sometimes a unseen stump gives a tippy surprise.
   / How much space for tire chains required? #13
Your manual shows the different possible wheel settings, but the widest setting will be with the center dished outward, the rim bolted on the outside of the center, and the weldments for connecting the rim to the center will be set so that the side of the rim that is closest to the weldments will be on the inside. Upon looking at mine to describe it, I notice it is set up that way except the rim is 180° from how I described for the widest possible setting, so you have PLENTY of room for adjustment. It's not hard to change the setting, just a matter of a few bolts, a little more awkward if the tires are loaded. Easier job with more than 1 person.
Yes, just went to manual after asking.
Been looking at a few of the pics of tractors with rear chains on other threads.
It doesn't seem like much space is required if the chains are put on tight and the slack is taken up. I don't plan on driving at high speeds on the road, or elsewhere where the centrifugal force should throw them into the fender.
With my little LX280 riding mower/snowblower, I usually let air out of the tires first, blowing them back up after the chains are on really snugs them up.
I would want to be able to pass my closed fist between the tire and any part of the fender both horizontally and vertically. How much you have depends both on the tire size and the position you have them mounted in.
Your tires are probably about an inch bigger in radius then mine but you should have plenty of clearance vertically but might need to move them out a position or two depending on how they delivered it to you.
In the upper picture with the chains, it looks like the center rim is on the inside of the outer rim 1' channel "tabs". Was this taken befor you put the spacers in? Can you take a picture that shows the tire width in relation to the fender?
   / How much space for tire chains required? #17
Better pic PMd to you. Those are all the way out plus 4 inch spacers which is how I had Trottier & Son ship it to me.
   / How much space for tire chains required? #18
Where abouts are you, vt?
   / How much space for tire chains required? #19
The Chelsea Brookfield town line up off Chelsea,s Williamstown road.
   / How much space for tire chains required? #20
Bethel here...about a mile or so north of the high school on RT 12.
Hi Neighbor!
(2) GREENLA HYD PUNCH DRIVER SETS (A58375)
(2) GREENLA HYD...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2002 Ford F-150 Pickup Truck (A56858)
2002 Ford F-150...
2008 Pace American 16' Cargo Trailer (A57148)
2008 Pace American...
2004 Kubota R520 S (A57148)
2004 Kubota R520 S...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
