How much tire fluid?
   / How much tire fluid? #2
I have a NH 1715 with a loader on it. It has turf tires. How many pounds of fluid should I put in the rear tires?
We need to know the tire size
   / How much tire fluid? #5
They are the 13.6-16 turf tires
This is using the rim guard tool. The weight is predicated on using beet juice (rim guard) as the ballast. Water would be less, and an alcohol mix would be less yet.
Tire Size: 13.6-16​
30 US Gallons
114 Liters
25 Imperial Gallons
Adding the suggested amount will add 321 lbs/146 kgs of weight and fill your tires 75% full
Did you know that Beet Juice is freeze resistant to -35° F, non-toxic, biodegradable, water soluble, and animal food grade safe?
FRONTIER AH11G LOT IDENTIFIER 100 (A53084)
FRONTIER AH11G LOT...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
LMC LOT IDENTIFIER 130 (A53084)
LMC LOT IDENTIFIER...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
