How much tractor?
/ How much tractor? #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
How much tractor does it take to adequately pull a 10'-12' disc?
/ How much tractor? #2
how many discs?
/ How much tractor? #3
Is it a disc moco or a 3 pt disc mower,or are you talking about plows
/ How much tractor? #4
6 HP per ft, so 60 HP minimum to around 75 HP. Pretty sure that 6 HP assumes a sandy loam, if there's much clay it would be higher.
/ How much tractor? #5
Assuming you're taking about a disc harrow, it depends on the kind of disk. If it's a regular tandem disc with approx 18-20" blades then it's like paulharvey said, about 6hp per foot, maybe get by with a little less. If it's a heavy built offset type with large diameter discs you will need more power.
/ How much tractor? #6
More than you would think in clay soil. MY 83hp (69pto) deere couldn't pull a 16' disc with any sort of speed about 4.5mph was its max and I was running out of ponies. Even had to downshift on the uphill. Constantly had to bump the hydraulic lift to keep from burying the machine. Disc wasn't set up properly but i sure didn't forget it was back there!
/ How much tractor? #7
Around 90 with about 12,000 # of well balance tractor
Balance the tractor 60 rear 40 front so with any type of disc in most any land you can traction
The older bigger models from the 70s and 80s were much better discing tractors.
/ How much tractor?
Would be a tow type disc harrow double row w/offset
2020 MACK GRANITE (A63569)
2020 MACK GRANITE...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
2013 BMW X3 28I XDRIVE (A61574)
2013 BMW X3 28I...
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
