MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,734
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
The topic of making a swap to gasoline equipment comes up occasionally mostly because of recent emissions equipment. A Kohler air cooled motor and a diesel is a far cry from the same thing. How much would making a gas motor with comparable durability as a diesel cost in comparison? Likely features would include a cast iron block, liquid cooled, lower rpm more toque than the average gasser, quieter, than the average gasser, and fuel injected. I知 thinking building a good gasser wouldn稚 be as big of a cost savings as some claim.
It's not that hard. Take a look at a 70's International 2500b, available with gas or diesel engines. Compare the specs. Very similar using the exact same transmissions. I don't know how much longer the diesel engine would last compared to the gas engine. My gas version had well over 4000 hours when I bought it with the hour meter broken. I worked it hard for a few years then light for about 7 more. So maybe 1000 hours more. It was still running strong when we got rid of it.
And lets face it, HP is HP and torque is torque. Doesn't matter what's making the HP or torque, if the numbers are the same, they are the same. A diesel will hold the torque curve longer than a gas engine in general, so that's one reason they would be preferable under varying loads like a tractor pulling a plow through varying soil conditions. Running a tractor loader around a yard (mine was a tractor loader), moving piles of material, maintaining a torque curve isn't as important. And the diesel will generally consume less fuel than the gas. To many small hour operators, fuel consumption is not a significant cost. To high hour operators, it all comes down to the bottom line, and every penny you can squeeze out is more potential profit.
For my little PowerTrac PT425, I run the Kohler gas engine at 3600rpms constantly. It's all hydraulic and functions best that way. My IH2500b manual said specifically to run the machine at least at PTO RPMS at all times to provide adequate hydrostatic pressure, cooling, and braking.
Anyhow, you can build a strong gas engine and gear it properly to provide the same power as a diesel engine. But I think you're going to have to provide a wider range of gears or gearing to allow the gas engine to be kept within it's torque curve under load compared to a diesel engine. I have no idea of the costs associated with engine building.
TractorData.com International Harvester 25 B industrial tractor information
