IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 15,802
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
I grease my tractor regularly just like my momma told me. I check to insure grease is actually extruding from the greased pin/bushing and occasionally have to clean out or replace a clogged zerk.
What I haven't done before is regularly check the tightness of all the the zerk fittings on the tractor, loader and backhoe. What a surprise I had today when I noticed that one zerk was loose. I noticed only because I regularly scoop out grease and grit from around the zerk with a small screwdriver before attaching the grease gun. One zerk seemed to move so I stopped and fetched a nut driver to tighten it. While I had the nut driver handy I decided to check all the other zerks. To my amazement, about half were loose. Some needed just a quarter turn to snug but a handful were really loose requiring several turns. It was not only the recessed zerks that were loose. Several flush mounted nipples were loose too.
I suppose they loosen due to routine vibration. There did not seem to be any correlation with type of grease fitting or how frequently the pin moved. The loosest pins were on the backhoe stabilizers which move much less than most other parts of the tractor. Loader and backhoe zerks were loose. None of the few on the tractor itself were loose.
My tractor (Kioti DK40se with Woods BH90x) is seven years old. Except for the occasional zerk needing cleaning, I'd never checked them for tightness before. I will now.
