How often do you clean your tractor?
   / How often do you clean your tractor? #11
Only wash before doing a full service...but, I always wips off fittings before greasing, daily clean the radiator and wipe around the fuel fill.
While I like my tools clean, this thing is for working and I am more concerned with maximizing my time and getting more done.
When everything on the property is finally done (some decade from now) I will probably wash regularly as having it clean does make me feel good.
I have only 50 hours on my B3030 so far and I asked to myself: why tractors at my dealer seem to be better than mine? And I was a bit sad because mine is nearly brand new and I didn't understand why I'd lost some of my enthusiasm when I look at it.
I found the solution: I washed it. I feel like I have a new tractor again. That's very therapeutic.
   / How often do you clean your tractor? #13
It wasn't clean when I got it,and it won't be clean if I ever sell it /forums/images/graemlins/grin.gif
   / How often do you clean your tractor? #14
I either washed my tractors with water, or blew the dust and such off with the air hose, nearly every time I used it, before parking it back in the shop building.
   / How often do you clean your tractor? #15
Stef; I used the same washing theory and put off buying a new pickup for three years /forums/images/graemlins/grin.gif The tractor gets washed several times a year, and waxed and detailed spring, summer, and fall. It does not take much time and makes me feel good.
Will
   / How often do you clean your tractor? #16
Don't think of it as washing, it's "inspecting, with a rag in your hand". Seriously, a good once over every now and then is a very healthy thing for any piece of machinery. Of course, having said that I don't exactly practice what I preach. Mine gets an "inspection" once or twice a year /forums/images/graemlins/smile.gif
   / How often do you clean your tractor? #17
Mostly dust around here now after 2+ months of triple digit temps.
Hose off the B7510HST almost every day at the well. This also helps clean the fine silt out of my newly-drilled well.
Grease the FEL fittings every 10 hours. Check the air filter then too.
Carry the 48" KK box blade around as a counterweight. Smear grease on the 3PH fittings once a week.
   / How often do you clean your tractor? #18
i usually wash mine 2 or 3 times a year, (depends on what i did with it) and usually throw on a coat of wax at least 2 times a year, but again i am retired so i have alittle more time to do those thing. /forums/images/graemlins/grin.gif i get enjoyment out of it
   / How often do you clean your tractor? #19
Perfectly normal. Mine gets washed evertime it rains! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
   / How often do you clean your tractor? #20
I never washed the B7500 for three years of ownership /forums/images/graemlins/frown.gif, I have washed the L2800 once /forums/images/graemlins/grin.gif since I traded the B7500 in April and that was right before doing the 50hr service.
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
Rubbermaid Water Trough - 100 Gallons (A55301)
Rubbermaid Water...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
UNUSED FUTURE FT15P EXCAVATOR (A54756)
UNUSED FUTURE...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
