how often do you sharpen your blades?
   / how often do you sharpen your blades? #11
Ive got a pair of identical 265 Deere mowers. One stays at the house, the other is at the farm. I bring the one at he farm home 2 or 3 times a season for service.
Last summer, I had someone recommend Gator blades as a replacement for the O.E.M. blades. I bought one set. I installed them on the mower that says at home. It cut better than I've ever seen EITHER Deere mower cut. When I brought #2 home for service, I cut part of the yard with it, and another part with #1 (with Gator Blades) The part cut by the gators looked MUCH cleaner than the part cut with the O.E.M. blades.
All the proof I needed. Now they BOTH have Gator Blades....
Last year, we also started using Gator blades on all the equipment at the golf course where they were aplicable.
   / how often do you sharpen your blades? #12
Fellas, I used to sharpen my RFM blades before I use it the first time in spring and that was it ,But now that I'm using a ZTR and it makes my yard look like a LAWN with its manuverability and striper I noticed a very slight amount of clumping the last couple mows and it hadn't had any of that when it was new this spring. So I finally did a deck cleaning and blade sharping yesterday. Used a nicholson single cut file for precise control of the angle and edge, it didn't take very long, (took longer getting the blades off,WOW were they tight ) Now the test will be when I mow next /forums/images/graemlins/cool.gif
   / how often do you sharpen your blades? #13
Well , If anybody is interested, the following cuts have not been much better, But I believe its due to HI-DEW levels in my mowing timing too late in the day trying to avoid some of the heat /forums/images/graemlins/crazy.gif plus it has been growing faster than I can get it cut ,been working too much to keep up with things ,so it was too tall for a good job to be possible....plus that late summer grass is coming in thick and causing most of this problem /forums/images/graemlins/confused.gif(kind of kelley green and always damp)YUK!!
One thing I have noticed is the sweet spot for a good job is about 3.25" or lower any attempt at getting a good cut with tall grass above that doesn't cut all the grass,That's probably due to the speed of the cut (why I bought a Z in the first place)of course speed and dampness has alot to do with the quality of the cut in the first place.
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
JMR stump/trenching bucket (A53421)
JMR...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
