How strong are trailer brake magnets supposed to be?
   / How strong are trailer brake magnets supposed to be? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I’ve spent the better part of the day troubleshooting my trailer brakes to no avail. As a last ditch effort I hooked the magnet to a battery charger and stuck it to a piece of 1/4 thick steel and I could drag it off with one hand. I think it should be way stronger. The magnets don’t appear to have much wear. It’s still 1” thick. It’s on a 10k axel.
   / How strong are trailer brake magnets supposed to be? #2
Put a meter on the magnet and check the resistance across the magnet leads, there is a spec. based on what size magnet/brakes you have.
The magnet isnt super strong, it relies partly on the friction material on the magnet and most trailer brakes are self energizing so it doesn't take a lot of force to apply them.
   / How strong are trailer brake magnets supposed to be? #3
I had a Ram pickup with a factory in dash brake controller, even on the highest setting, had very little trailer braking.
Same trailer I had used for years with aftermarket controller with no issues. Just for fun, hooked it up to the Ford
with factory brake controller, and it could once again lock up the tires when the trailer was empty.
Moral is, may not be the brakes, may be controller
   / How strong are trailer brake magnets supposed to be? #4
Or it could be the brakes need to be adjusted.
My understanding is; jack wheel off the ground, tighten adjuster until you can't spin the tire, loosen adjuster until you can spin the tire. Done
   / How strong are trailer brake magnets supposed to be? #5
Good video on how brakes work.
I’ve already adjusted the pads. I’ve already hooked another trailer on the truck. I’ve already hooked a battery direct wired to the brakes.
   / How strong are trailer brake magnets supposed to be? #7
I had electric brakes on a 9 ton tri-axle trailer and with a 12k machine on the trailer I could lock up the brakes at 35 mph if I didn't adjust the gain on the controller correctly. It sounds like your magnets aren't working correctly.
   / How strong are trailer brake magnets supposed to be? #8
What is the amp draw on the system and individual magnets? What's the ohms reading across the wires for the magnet? That will tell you whether its electrical or a mechanical issue. Here's a good writup on testing trailer brake magnets.
Testing Trailer Brake Magnets for Proper Function | etrailer.com
   / How strong are trailer brake magnets supposed to be? #9
Also, the wires tend to break off right at the magnets from movement bending the wires. Maybe the wires are partially broke so they are not using as much amps as they should?
   / How strong are trailer brake magnets supposed to be? #10
Agreed!
With my trailer gross at 12K I can set the electric brakes to bring my GMC2500 Suburban to a normal (without trailer type normal) stop.
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
2017 John Deere HPX 4x4 Gator Utility Cart (A56857)
2017 John Deere...
Schuttle S100 (A57149)
2017 TROXELL 130 BBL STEEL VACUUM TRAILER (A58214)
2017 TROXELL 130...
2008 Ford F450 Lariat Pick Up (A55272)
2008 Ford F450...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
