How tight do I adjust my stabilizer arms?
   / How tight do I adjust my stabilizer arms?
Thanks all. I've snugged them up a bit. The pivot point of the stabilizer is aligned with the pivot point of the 3-pt arms, so there's no change in tension through the lift range.
   / How tight do I adjust my stabilizer arms? #12
I keep them loose enough to spread around the attachment pins on the accessory, but not so loose the accessory slops over and rubs the rear tires. What else is there?
-shu
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
black Max power washer (A53421)
black Max power...
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
