how tight to twist fencing brace wires?
   / how tight to twist fencing brace wires? #21
We use them for everything. Braces, wire terminations, tensioners. Only ever had them come apart When cars go through the fence.
I used the crimp on connectors on one fence. It was a high tensile smooth wire. They did ok if you had 4-5 crimps on them. Almost solid crimp. Two just wouldn't hold. I always twist tie my brace wire. Wrap it atleast 8 times and try to get your wraps to touch and it'll hold what ever the wire will. If you don't get the wraps to touch then they'll slip till they pull in together.
   / how tight to twist fencing brace wires? #22
You must have been been using the wrong size crimps or the wrong size crimp tool. Two will hold any thing the wire will.
   / how tight to twist fencing brace wires? #23
Pretty sure the crimps were the right size but I wasn't happy with the tool. It didn't wrap around the crimp but instead looked like a bolt cutter but it would cam over.
   / how tight to twist fencing brace wires? #24
The tool we used had a bolt cutter appearance but had 4 or 5 different sized slots. actually it looked like a really thick wire strippers. the jaw would completely cover the crimp. You could not crimp the little buggers shut with one hand even though it had 24 inch handles. The only way I was ever able to get the wire back apart was to take bolt cutters and mash and slice to get the crimps broke apart.
   / how tight to twist fencing brace wires? #25
Yea I've seen those. They may work better than what I was using. Instead of the different size holes these had flat jaws. Where about the same length.
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2014 Ford Escape (A50323)
2014 Ford Escape...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
