How to adapt 2 volt clay pigeon thrower to 110 electric
   / How to adapt 2 volt clay pigeon thrower to 110 electric
Your title says 2 volt.. I am kinda doubting that.. did you mean to say 12 volts? Yup you are right,, I would like to eliminate the battery all together just pull it out of the barn and plug it in, no battery involved!
   / How to adapt 2 volt clay pigeon thrower to 110 electric #12
Can you tell us more about how it works? Does it have any kind of electrical data plate on it? If so what does it say? What we are fishing for, is what is the maximum amount of current the unit draws at that 12 volt rating. IF we knew that we could then find and recommend a power supply for you.
   / How to adapt 2 volt clay pigeon thrower to 110 electric #13
I have two battery skeet throwers;There is a spring that actually "throws" the bird ,power is to re-cock.
Mine are on marine batteries and solar chargers;they work all summer with no problems.
   / How to adapt 2 volt clay pigeon thrower to 110 electric #14
Do you have any idea what the current draw is while it is cocking the spring?
   / How to adapt 2 volt clay pigeon thrower to 110 electric #15
I also have two 12V throwers. The motor cocks the spring. I don't know what the draw is but it is high. The motors really struggle to cock the things. I don't think a 30amp astron would cock it. (I have one). The simplest way to do this is just hook a battery charger to the thing. and leave everything else be.
   / How to adapt 2 volt clay pigeon thrower to 110 electric #16
I would tend to agree.
   / How to adapt 2 volt clay pigeon thrower to 110 electric #17
I think that I would just get two group 27 deep cycle batteries and a battery tender, wire them up parallel , keep them inside the barn and run appropriate wiring to the throwers. If you take proper care of those batteries, they would last for years.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
2011 Ford F-450 Dump Truck, VIN # 1FDTF4GTXBEC82149 (A54865)
2011 Ford F-450...
