Not only will you cause a miss but you will ruin the end of your feeler gauge blade.
You are inserting the feeler gauge between the rocker arm and the top of the valve stem? Just above the spring??
:wrench:
Yes between valve stem and rocker arm.I set the clearance to 0.010 and a 0.011 is tight but 0.010 slides through when cold.
After replacing the plastic cam gear and faulty ignitor it's a different motor,has more power.
