How to adjust governor arm and lifters ?
   / How to adjust governor arm and lifters ?
Not only will you cause a miss but you will ruin the end of your feeler gauge blade.
You are inserting the feeler gauge between the rocker arm and the top of the valve stem? Just above the spring??
:wrench:
Yes between valve stem and rocker arm.I set the clearance to 0.010 and a 0.011 is tight but 0.010 slides through when cold.
After replacing the plastic cam gear and faulty ignitor it's a different motor,has more power.
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
BESTWAY AG VSK50 LOT NUMBER 104 (A53084)
BESTWAY AG VSK50...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
