How to best smooth trails
   / How to best smooth trails #11
I use a box blade, rippers attached if I need to dig down. A landscape rake can be used to smooth out the work somewhat but I don't have one and the box blade get's me 80%-90% of where I'd like to be. I angle the blade to cut deeper on one side of a slope with the manual lift arm adjuster (I don't have top & Tilt). Kind of a pain but then I don't try to build the road in one day. I then use the box to bring filler up to the low side/spots. Also adding weight to the box blade helps keep it down and digging vs. popping up when it meet enough resistance.
   / How to best smooth trails #12
Although my rear blade and rake do a great job on most of my paths, I have two or three spots where I have some areas with dips on the side of the path for about 10 feet long on some flat land (say 5 to 8 inches lower than what is needed to drain) that collect water in the winter and make a mess.
I tried with the rear blade turned a big angle to cut down drains on the side of the path but the blade does not dig in far enough (it was pretty wet when I tried it). Would it be wise to get a middle buster and straddle the ditch with the tractor and dig them out before I use my rear blade? I don't have one but would buy one if this would help.
230112 (A53422)
230112 (A53422)
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2003 CATERPILLAR M316C MOBILE EXCAVATOR (A52707)
2003 CATERPILLAR...
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
John Deere 7410 (A53317)
John Deere 7410...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
