How to change loaded tire?
   / How to change loaded tire? #21
Dad got a good deal (less than $100) on a manual pallet jack,
we take both the tires and brake assembly of semi trucks w/it
this will do what u need too.
These jacks are handy for moving everything and complement a set of forks too.
Well,
It's three months later, but I finally did it. Had some work to do in the woods, didn't want to get a flat.
Used Beenthere's method. Worked like a charm. All four tires changed in <30min. New Holland was nice enough to mount the rear wheels using two studs and 4 bolts. If it were all bolts (like the fronts are) it wouldn't have been easy. I probably would have made a stud out of threaded rod to aid me.
Thanks everybody for your advice. - In case you're wondering the bathroom scale is doing fine /forums/images/graemlins/tongue.gif
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
2016 Volkswagen Jetta Sedan (A56859)
2016 Volkswagen...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
