How to change the filter for transmission/hydraulic oil without changing oil?
   / How to change the filter for transmission/hydraulic oil without changing oil? #11
At 50 hours I changed every oil/fluid/grease on my tractor. I saved nothing. My big almost "OOPS". The hydraulic system holds 16+ gallons. Thankfully I did a dry run. I could NEVER pull/replace five gallon pails without massive spillage. The only container large enough - my wife's large Tupperware quilt container. A new quilt container cost around $20, as I remember.
:laughing: I am sure you wiped it out so she could put her quilt back!
   / How to change the filter for transmission/hydraulic oil without changing oil? #12
Not a chance there - 5Klwq. I bought her a new one. That's how I remember the price. If I would have tried that trick - - bad dreams of my wife pulling a Lorena Bobbit.
   / How to change the filter for transmission/hydraulic oil without changing oil? #13
Maybe be prepared in future with big tub.....
Dale
   / How to change the filter for transmission/hydraulic oil without changing oil? #14
To each his own. My method is to have a catch container to catch the loss. Have the new filter conveniently near by. Get the filter unstuck and ready to back off easily. Spin it off using both hands, one on either side as fast as you can and stab the new one, reversing the process. Even on 4x10 spin ons, you'd be surprised how little you spill. I think the main thing going into it is knowing what you are up against and not being panicked when more comes out than you thought you'd have.....like what comes out on changing an engine oil filter. When finished, check the level and top off if necessary.
On catch pans, I use Dollar General plastic rectangular tubs, with one end cut down so I can work the filter. Use the same one for engine oil changes...slides easily up under the equipment whereas 5 gallon buckets are not the right choice.
   / How to change the filter for transmission/hydraulic oil without changing oil? #15
Just so you all know, there is another way beside the vacuum. It is called stop up the vent hole. Find the vent hole for the tractor transmission/reservoir. On Kubota's it is under the seat. Little rubber shepherds crook. For a Kioti it is built into the filler rubber cap. Again a crook pointing down. Stop up that crook's hole. Usually a number 8 sheet metal screw will work fine. BUT DON'T FORGET TO TAKE IT BACK OUT WHEN YOU ARE FINISHED. Don't ask me how I know. Now have filter unwrapped and oriented to grab. Remove old filter and quickly put on new filter. Usual spill is less than 1/2 quart. Why does this work you ask? Because without the vent hole above the liquid line air cannot get into the reservoir. The only way air can get in is for liquid to come out the filter hole. Sure a little liquid comes out, and a little air gets in the same way, BUT it is VERY little. Less than 1/2 a quart if you are ready.
Oh by the way if you forget to remove the vent screw and cycle the loader when the loader comes down the dipstick gets blown out into the yard and you get to go look for it. As you may or may not know every time you cycle the loader or any 3pt implement, a large quantity of air gets sucked into your reservoir and when the loader or implement is lowered a large amount of fluid goes into the reservoir and the same volume of air is blown back out the vent. Yes moist humid air is sucked into your transmission all day. And as long as you run the tractor enough to get the oil hot the water vapor goes back out as vapor and does not condense in the bottom of the cold transmission as water. There now you all learned something (or not) and it was free. :)
   / How to change the filter for transmission/hydraulic oil without changing oil? #16
That's why we come here.....good explanation, keep em coming. :thumbsup:
Thank you, everybody!
As to the crook on the top of the Kubota hydraulic space... so THAT'S what that thing was! (but that was my old tractor not the current one).
Yes, I did get the new filter to seat. I don't know what kept going wrong the first several times. I was getting a pretty good stream draining out, like the gap must have been at least 1/16" and maybe 1/8". It would rotate several turns and then stiffen considerably, which felt like it was seating, but visually it obviously wasn't. The old filter gasket kept sticking to the tractor rather than coming off with the filter, but I knew that and was dealing with that. I felt for some other obstruction but never found it. Of course I was frantically trying to stem the tide, so it wasn't a great time for thoughtful examination and testing ideas. I'm stuck clueless as to what the problem was. However, eventually it worked, and worked perfectly well as I'd expect with no question about it, and I wasn't about to experiment any further.
About the vacuum cleaner idea, I wonder if the vapor over the oil could be combustible, ignited by the brushes in the vacuum cleaner motor. But I think if it was, that's what most of the stories would be about.
So now I have a NEW PROBLEM. The loader hydraulics are very spongy. I often park with the loader close to the barn door, and just walk across the blade edge if I want to take the shortcut in my fairly small storage area. And I generally get the bucket pretty level when I park and shut down. But yesterday I noticed the bucket was curled a bit and still resting on the ground, and when I walked across it, the loader arms and the bucket were both flexing significantly under my weight. Tractor's new, with nice tight joints, but I could feel with my finger that my body weight was moving the cylinder rods in and out a good quarter inch. Now, I could stand to lose a few, and keep some of my ballast right behind the steering wheel, but this is definitely off!
What I had done after my refill, without having let anything hydraulic move, was to run for a while until the engine was warm. I wanted the air in the filter and lines to get pumped into the tank, not into any cylinders. Only then did I cycle the loader arms, the bucket, and the 3 pt. But I think I must have air in there all the same. I did also notice an unfamiliar, faint, high pitched whine when I started, before I used any hydraulic motions. So I've been reading up on getting rid of air. Any advice would be VERY APPRECIATED!
   / How to change the filter for transmission/hydraulic oil without changing oil? #18
Most systems will self purge the air out,
just fully stroke all the cylinders several times.
Thanks! I'm going to try this at lunchtime. I have a urethane edge for the bucket to install, anyway!
And I'm not above being amused by watching things go up and down again and again....
...and it seems better now, after eating my peanut butter sandwich watching things go up and down again and again....
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
Chevrolet Metal Tailgate Art (A55853)
Chevrolet Metal...
2013 PETERBILT 367 TRI-DRIVE WET KIT (A55745)
2013 PETERBILT 367...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
Heil 28Yd Side Loader Garbage Truck (A55852)
Heil 28Yd Side...
24613 (A55853)
24613 (A55853)
