How to convert Cat 2 Brush Hog for Cat 1 Tractor
   / How to convert Cat 2 Brush Hog for Cat 1 Tractor
The 609 frame which holds the lower pins is a boxed design, so the threaded end (1 1/8" dia) needs to be at least 3 5/8" long, to allow length to pass through boxed frame, and room for nut. This would put the Pin overall length somewhere over 6".
   / How to convert Cat 2 Brush Hog for Cat 1 Tractor #22
I just ran into the same situation this week on a older IH sickle bar mower. The box frame was 2 1/2 thick and I could find nothing available with that long threads and still room for a nut and lock. I am putting a pin through and welding it on both sides of the box frame. Ken Sweet
I plan to remove the existing Cat 2 pins, bring them to a friend of mine, who can machine them to the correct length and diameter, which will align with my Cat 1 needs on the machined end, and fit the 609 exactly. (on the threaded end)
   / How to convert Cat 2 Brush Hog for Cat 1 Tractor #24
They do make them, just don't know if it is long enough for what you need. I use them on my cat II blade and cat I tractor. I bought mine at a local tractor dealer, but here is the 7/8 pin and 1 1/8 thread at sloanex.
New Sloan Express
I built a cradle for the cutter this weekend. (2 4x4's, mounted to engine stand with dolly's) Removed the Pins. (man are those Cat 2 pins heavy duty)
Originally planned to have a friend machine them down to Cat 1 size. However, I decided to look again, at any suppliers that may have the extra threaded 1 1/8" length I need to pass through my JD609 frame mount. (need at least 3 5/8" length between collar, and end of threads) I just located Tractor Parts Inc., who appears to have a product (TP2032) that would provide the threaded end length. Sent a email this morning. If anyone from TBN has any experience with this parts vendor, would appreciate any feedback on their experience.
   / How to convert Cat 2 Brush Hog for Cat 1 Tractor #26
Did you check your local TSC store? I know they have extra long Cat 1 threaded pins with two nuts to accomadate various thicknesses of material, but I'm not sure if they would be able to handle the 3-5/8" thickness you refer to. Obviously, you'd still have to slip a shim over the threaded portion to match the OD to the hole, but they sell those also. Finish it off with about a 2" extra-thick washer.
After my neighbor machined my CAT2 pins to CAT1 dimension, I Managed to get the JD609 attached. This was in the fall of last year. I am at the outer limit for my sway brackets. I then wound up the RPM's, and was very pleased with how smooth this older unit runs. I took it over some soft grass, then some small trees. WOW what a unit. The Power and sheer mass pulverizes anything you can push over. I am amazed and very respectful, of the power this brush hog has. One thing I need to figure out is how to attach safety chains to the PTO shaft cover. This PTO shaft cover is substantial. (heavy steel with poly/plastic underneath. (next to revolving shaft)
I am still trying to find 2 1/2" Open End Wrench, to correctly adjust the Slip Clutch, before this year's mowing starts. I also plan to run the unit, get the oil warm, and change it.
I also will be attaching the debris guards front and rear. (most likely will go with the less expensive rubber, since I have no need for the more expensive chains) All I need now is a large 3pt spreader; (to prep my crop plots with pelletized lime, and fertilizers) and cultivator/disc. (to work leaves/grass/manure/mulch into soil) I really appreciate all those that have contributed to help me out. I am amazed at the speed and force of these machines, when properly equipped.
Here is a close-up of the re-machined Cat2 pins on the JD609:
mail
This is my first picture I have attempted to insert into a note. (hope it works)
You can see the boxed frame portion of this pin is very large in diameter. It secures the boxed frame, and the 3pt arm. I could not find bushings long enough to span across the boxed frame. Using the original pin has allowed me to secure this with a solid "fit". (also cannot swap this pin to the inside, unless the boxed frame was re-machined. Diameter varies between outside and inside)
Another try at posting the pin close-up pic.
   / How to convert Cat 2 Brush Hog for Cat 1 Tractor #30
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
CAT 930M (A58214)
CAT 930M (A58214)
1459 (A57192)
1459 (A57192)
