How to cut steel belted tires?
   / How to cut steel belted tires? #1
Doughknob
Veteran Member
ohio
Deere X500, Bobcat CT4045
Anyone have a good way to cut up steel belted tires?
I have tried many hand tools and hand held power tools but have found nothing up to the task of relatively smoothly slicing through the belts.
   / How to cut steel belted tires? #2
I cut some for disposal by cutting along the sidewall, just outside the tread, with a utility knife, then rolling up the tread. I cut the bead with a grinder on two sides. Two tires fit easily into a garbage can.
These had no steel in the sidewall, only in the tread.
Bruce
   / How to cut steel belted tires? #3
I used an Ideal tire groover with good results, grooved out the rubber down to the steel belts, then used a cut off wheel to cut the belts.
   / How to cut steel belted tires? #4
Sawzall with a bimetal/demo blade works fine.
   / How to cut steel belted tires? #5
Big ole chop saw. Smelly but works. They burn good too. There are videos on how to cut them up with a home rigged contraptions. I have well over a thousand myself. I don't know how many you need to move. Had a fella call the other night wanting some to burn because they were having a funeral and it was kinda cool out. Boys, it's poor here in rural Arkansas. I've seen that same guy get a dead coon off the road and pick the maggots out and go catch a mess of fish with the maggots.
Hmmmm..... I have tried a sawzall with a 'metal' blade. Not sure it was "bimetal" though. I have thought of trying it again but clamping the beasty down tighter so it doesn't just flex as I cut. I will also look for "bimetal" blades.
LOL! I have tried a metal-cutting blade in my circular saw and I did indeed get some small flames as the blade melted and set fire to the rubber as it tried to cut the steel cords!
I have thought of trying a fiber cut-off wheel but didn't think it would work for the rubber. I did not want to do separate operations - just wanted to cut it with one pass. But I may have to rethink that. Thanks.
   / How to cut steel belted tires? #9
Diamond blade on an angle grinder goes right through the steel.
1998 MACK DM690S MIXER TRUCK (A50854)
1998 MACK DM690S...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
DOG HOUSE/CONTAINMENT SLID (A50854)
DOG...
2012 CAT 930K (A50854)
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A50854)
GROVE RT 63S HEAVY...
