How to determine true south?
   / How to determine true south? #11
Got a GPS? Stand still at the location you want to put the panel. take a few steps to your best guess at south, look at the reading, adjust.
It'll be close enough. I think to get the max out of it you'l lhave to move the panel several times a year since it changes with the seasons and the earths wobble if I remember some reading.
   / How to determine true south? #12
Use a Garmin eTrex Vista's built-in GPS compass.
   / How to determine true south? #13
I figgered there was going to be a redneck joke in here somewhere.
   / How to determine true south? #14
Variation on Slamfires method.
The sun follows a straight path thru the sky, it's shadow does the same on the ground. Take a stick(preferably round as it will cast the same shape shadow over time)about 2 feet long and place it in the ground vertically. An hour or two before noon, mark where the end of the shadow from the top of the stick falls. A few hours after noon, make a second mark where the end of the shadow falls. Draw a line between the two marks you made and you have a East-West line.
   / How to determine true south? #15
I hope these guys didn't confuse you as much as they did me!
   / How to determine true south? #16
Put a stick in the ground. When the shadow is the shortest the sun is due south. Since it's now daylight savings time you should only have to watch from noon till 2 pm. If you know where you are in the time zone you can narrow down that period. For example, if you're closer the western edge of your time zone then watch from 1 to 2, or noon til one if you're closer to the eastern edge.
   / How to determine true south? #17
Gatorboy said:
Go to the North Pole and every direction will be south. Very simple.
Gatorboy,
Of all your wisecracks, that has to be the best one EVER. LOL
Stumpfield,
I thought you were going to get dual axis solar trackers?
3RRL said:
Stumpfield,
No, definitely no trackers for me. I would advice anyone NOT to use trackers. It's great for those who sell and charge $$$ to maintain them. Trackers are best use for other solar applications. IMO, it's better to use the $$$ to buy more panels to make up the difference. ...unless you have a space limitation and no room for more panels.
   / How to determine true south? #19
Farmwithjunk said:
Oh! THAT true south. I thought you were talkin' Rebel flags, Grits, and Y'all come back now, he'ya.;)
Exactly what I was thinking. :D From where he is the directions are simple...head away from the ocean and turn right when you hit the 'All you can eat signs'. :D
   / How to determine true south? #20
Find the North star at night and south will be directly opposite. The Noth star is accurate enough to line up a satelite dish with a polar mount and they are very unforgiving.
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2012 CATERPILLAR...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A54757)
UNUSED WOLVERINE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2014 Top Hat T/A 18FT Utility Trailer (A52377)
2014 Top Hat T/A...
