How to fix crack in plastic fender
   / How to fix crack in plastic fender #11
I work in injection molding and know plenty about plastic.
You almost can't fix it. Save your money and time and either live with it or buy a new fender.
   / How to fix crack in plastic fender #12
Just a thought ... after you stop the crack with a hole as described before, you might try some Gorilla Glue from the underside. I know nothing about plastics except this stuff has worked for me. I broke off my left side mirror on my car at the 3 plastic (internal) studs and glued it back on ... 6 months ago ...
Cheers!
   / How to fix crack in plastic fender #13
</font><font color="blue" class="small">( We will be seeing more of these types of posts though as the plastic coated tractors age a bit. )</font>
My 4310 fender is also cracking, but a lot lower down. I saw it a couple of weeks ago when I was taking parts off to get at the loader joystick for lubrication. On the plus side, the fenders have no dents. /forums/images/graemlins/laugh.gif
Tom
   / How to fix crack in plastic fender #14
I had a big crack in mine after winding up a chain harrow around the rear wheel (ouch!). Tried fixing it... held together about a day with cycloarcanate (super glue)... a week or so with JBWeld, a couple of weeks with duct tape... and the fender was looking worse and worse on my nice new tractor.
Finally gave in and spend the $800 to replace it with a new one. MUCH happier now, not looking at the ugly cracked fender and reminding myself of my past error every time I get in the thing.
   / How to fix crack in plastic fender #15
Metal can always be repaired and repainted. Plastic has a definate lifespan and deteroriates. But we have to live with plastic, because that is what we get.
Ben
   / How to fix crack in plastic fender #16
One of the reasons I didn't buy a Mahindra was cracked plastic fenders on a used model sitting on the dealers lot. It had very, very low hours -- no more than ten, I'm sure. There was a crack at each bend in both rear fenders.
   / How to fix crack in plastic fender #17
I wonder if selling metal replacement fenders and hoods for tractors with plastic coverings would be a viable business in a few years ?
Ben
   / How to fix crack in plastic fender #18
Slowrev,
I will buy stock in the first company that does it. I never had much luck with repairing anything plastic other than Fiber Glass.
Farwell
   / How to fix crack in plastic fender #19
Farwell,
Yes fiberglass is no problem to repair. I have not had any luck either with repairing plastic body parts either. Gluing a plastic switch housing together or something like that is not a problem, but the flexible plastic.......And at 800.00 a pop for a fender......
But that is what almost everyone is putting on at least the small to mid sized tractors. I suppose it is a good way to increase profits on parts sales /forums/images/graemlins/smile.gif
Ben
   / How to fix crack in plastic fender #20
Yes you can fix plastic. You have to know what kind it is so you can by the correct repair material. I have worked in the autobody repair industry since the mid 1970's. I have succsessfully repaired all kinds of plastic parts on all types of vehicles. I have done tests where I bonded pieces of plastic to old plastic parts such as fenders. I hooked the parts to our frame machine and pulled until the part broke and the bond held. 3M also makes adhesives for plastic to metal and metal to metal. I have bonded metal to metal and pulled until the metal tears and the bond held. I can fix a crack or tear in a plastic part so well that you could not find the repair. Plastic can be repaired.
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
Giyi Mini Land Leveler (A53316)
Giyi Mini Land...
CFG Industrial MH12RX (A53316)
CFG Industrial...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A55302)
2012 Ford F-150...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
